Oil Filter
Old May 27, 2007 | 12:46 PM
DRE073's Avatar
Oil Filter
Ok, So I Just Bought An 03 Sedan And I Was Trying To Change The Oil But I Cant Locate The Oil Filter, Any Ideas On Its Location. I Bought The Oil Filter From Advance Auto Parts. Its The K&n Brand Oil Filter And It's Smaller Than Most Filters That I've Seen. Is This Normal?
Old May 27, 2007 | 12:48 PM
g35sedan5at's Avatar
the oil filter is under the engine, i think theres a slight opening for it in the bottom engine cover, if not, prepare to take off some 10mm screws
Old May 27, 2007 | 12:52 PM
DRE073's Avatar
I Hope I Dont Have To Remove That Enegine Covr At The Bottom There's Like A Million Screws. Thanks Anyway
Old May 27, 2007 | 12:59 PM
gary c's Avatar
Oil Change/Filter too..............!
The oil filter is under the panel that covers the front section of your car.
Don't try to change the filter thru that small hole, you could make a mess.
Remove the 10 mm bolts and drop the panel this will give you access to the
filter. Good choice of filters! The first time I purchased a filter for my G
I asked the clerk, "Where's the rest of the filter!" Do a search on-line for
the K&N's......you should be able to find them for $8 and change plus shipping
will be free if you buy three........Good Luck!
Old May 27, 2007 | 01:06 PM
DRE073's Avatar
Sounds Good.
Old May 27, 2007 | 01:15 PM
ttrank's Avatar
Grocery getter
I use a skew (right angle) adapter on my drill and a 10mm to drop that part. It only takes a couple mins. The good news is that the filter is right there, just above the oil pan. It was way more of a pain on my last Honda.
KruZZe
Feb 27, 2023 05:04 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
vamarris
Sep 26, 2015 12:56 PM
