KP technologies WINDOW ROLL UP
Old Jun 4, 2007 | 04:35 PM
killerlexus's Avatar
now i can roll my windows up and down with my remote.
Old Jun 4, 2007 | 04:43 PM
izmir41500's Avatar
G35driver Addict
was the install difficult?
Old Jun 4, 2007 | 05:01 PM
AgentRice's Avatar
http://www.boostedconcepts.com/kptech.html
50 bucks shipped.. not bad!
might order this
how was the install?
Old Jun 4, 2007 | 05:09 PM
G35Dreamz's Avatar
i have this module but for my 03 Accord coupe and it works great. Does this one(1) unit control all four(4) windows or you have to buy another for the back?
Old Jun 4, 2007 | 05:53 PM
perry05G35's Avatar
Cheaper than a smart key.
Old Jun 4, 2007 | 07:37 PM
VQ Hotness's Avatar
Ive always been able to roll them down, just cant roll them up. 50$ not bad
Old Jun 4, 2007 | 07:49 PM
ttrank's Avatar
Grocery getter
I have had one of these for a while. Kevin makes awesome stuff.
Old Jun 4, 2007 | 07:54 PM
havent installed yet. kinda of wet around here for last few days now. hopefully the weather will clear up by the end of the week.
Old Jun 4, 2007 | 08:13 PM
ttrank's Avatar
Grocery getter
It's an easy install. Just have to pull the door panel. Took me about 20 minutes.
Old Jun 4, 2007 | 09:07 PM
chobble19's Avatar
kp makes goo dstuff! had mine in for a while now and it comes in handy in this 90 degree weather over here. i used it twice today!
Old Jun 4, 2007 | 09:13 PM
pretty straight forward insturctions. so simple!
Attached Thumbnails KP technologies WINDOW ROLL UP-window-roll-upinsturction2.jpg
Old Jun 4, 2007 | 10:26 PM
Allenzi35's Avatar
I have a question....
1. Does this work on 06 G's?
2. Instead of using the remote, can this be used with the little black rubber button on the door? (Intelligent Key)
3. Is this for all windows or just one window?
4. If it is all windows, is the install only in one door or ALL doors?
Thanks
Old Jun 4, 2007 | 11:07 PM
ttrank's Avatar
Grocery getter
Thanks
Send these to KP to be 100% sure.
Old Jun 11, 2007 | 06:02 PM
KPierson's Avatar
Should work on all '06s without an issue.
It works off of door lock actuator pulses, so if by pushing the little black button on the door locks the door EVERY time you push it then it will trigger the module (you can also trigger the module from the inside 'lock' button IF the ignition is switched off).
One module will control all anti pinch protected windows. To quickly find out if you have 4 anti pinch windows lower all four windows then insert your key in the drivers door key cylinder and turn and hold it in the 'LOCK' position for a few seconds. If all four windows raise then you have anti pinch on all four, if only the front two raise then you only have it on the front two. Pre '06 you had to have the premium package to have anti pinch on the back windows.
It is one module that installs in the drivers door only. It sends a low current comm signal to the BCM to request that it raise the windows. The module is completely low current and will draw less then 20mA when raising the windows.
Dallsinghjr1
Sep 17, 2023 11:25 AM
DRG35R
Jan 31, 2016 07:14 AM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
NyCrAzY
Oct 1, 2015 09:19 AM
