Is this normal for 98 degree weather??
Old Jun 4, 2007 | 08:46 PM
digital1986's Avatar
Never had the temp that high before. I had to turn the ac off (yes leave in sedan section)
Old Jun 4, 2007 | 08:55 PM
350.GT's Avatar
ahh....no. you should check your coolant.
-Loc
Old Jun 4, 2007 | 09:24 PM
5150DS's Avatar
I've driven in 120 and the needle never moves much above the middle. Check your thermostat also.
Old Jun 4, 2007 | 09:43 PM
damn! this isnt good. Good thing I have my 70K mile check up coming this Saturday!
Old Jun 4, 2007 | 10:13 PM
nghiars's Avatar
yea man... somethings wrong..
Old Jun 4, 2007 | 11:15 PM
ttrank's Avatar
Grocery getter
+100 something is not right.
You either have air in your coolant line or a clog somewhere.
Old Jun 4, 2007 | 11:56 PM
I will follow up with you guys and let everyone know whats wrong!
Old Jun 5, 2007 | 01:27 AM
jack_burton's Avatar
ahhh, not good.
I'm guessing it's low coolant or your therostat is busted, or your driving 150 MPH for a long time
Old Jun 5, 2007 | 06:03 AM
johnsonhuang's Avatar
that happened to me a few weeks ago. i had to pull over cause it was starting to go into the red zone. popped the hood, found out the coolant was boiling. Checked all the places i parked and there was no leak. no coolant leaks in the hoses.. it was CRAZY hot the past few days though and had the AC blasting non stop. checked my coolant and i had to add a full GALLON to it before it filled back up to normal. thank god when i started overheating, i was only 5 blocks away from a Kragen =P
Old Jun 5, 2007 | 07:48 AM
kevink's Avatar
I regularly drive when it is over 100deg, 75-80 mph, and mine is pegged right in the middle. Even with air on. The only thing that happens when I drive a distance in the heat is my TPM light likes to turn on.
Old Jun 5, 2007 | 08:31 AM
chaindrive's Avatar
that happened to my frontier i checked the coolant overflow bone dry let it cool radiator half empty nissans must lose coolant to evaporation in hot summer months.
Old Jun 5, 2007 | 08:33 AM
G35stilez's Avatar
Concours d'Elegance
My Integra did that a lot.
If there isn't a leak or low coolant, your thermo is on the way out. Get that replaced ASAP.
Old Jun 5, 2007 | 03:33 PM
falconey's Avatar
Actually I think leaving your A/C on should help with overheating because it's forcing the fan to blow. Not sure how many fans these cars have, but I'm sure it's two? Make sure both are working properly. Then as everyone else said, check coolant and next the thermostat. Good luck.
Old Jun 5, 2007 | 03:41 PM
ttrank's Avatar
Grocery getter
Did you check your coolant level yet? If you have to add a bunch make sure and clear the line of water via the plug on the back pass side of the motor. If you have air in there it will do that.
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
Learned Hand
Oct 1, 2015 09:02 AM
aaron3719
Sep 29, 2015 10:12 AM
