Why doesn't 260hp/260tq light up tires more easily?
Old Jun 10, 2007 | 12:20 AM
DP03's Avatar
Its very simple. Forget all the excuses above. Need more hp......My wifes Camry has all the eletronic doo dads as well and still beats the G...My SRT, on the other hand......it's an utter annilation....
No one gives the 268 hp Camry respect on this board. Fact is, it will smoke the G (its 6 speed tranny is the key) unless it's a VERY talented 6M driver (like it or not, there are not that many out there ).
Old Jun 10, 2007 | 01:31 AM
VQ Hotness's Avatar
I wish i could get traction... My 1/4 mile times would be easily .50 to a sec faster... If you really want to lose traction wait till it rains.
Old Jun 10, 2007 | 02:21 AM
DaveB's Avatar
I'm going to have to disagree with you. There's no way a Camry v6 6A is going to "smoke" any G35, auto or manual. I give the new Camry a lot of respect in terms of it's power, but from what I've read on the Camry boards and what I've seen in the mags, it's pretty much a toss up when comparing the 1/4 mile performance of the 5A G35 and 6A Camry.
Old Jun 10, 2007 | 06:41 AM
jimmyc13's Avatar
Originally Posted by killerlexus
its an auto.. even with the traction off, the car will not break loose.
its sluggish till 3ooo rpm.
Your sig. says you drive an X. I believe turning the VDC off in your car won't do anything & you really can't increase your chances of burning out. The only way you can turn off your front drive I believe is by pulling the AWD fuse.
Can anyone on here correct me if I'm wrong here?
Old Jun 10, 2007 | 08:19 AM
DP03's Avatar
Originally Posted by DaveB
I'm going to have to disagree with you. There's no way a Camry v6 6A is going to "smoke" any G35, auto or manual. I give the new Camry a lot of respective in terms of it's power, but from what I've read on the Camry boards and what I've seen in the mags, it's pretty much a toss up when comparing the 1/4 mile performance of the 5A G35 and 6A Camry.
Dave, I respect your opinion. Maybe I just came accross bad drivers while driving the wife's car.........the one thing I don't like about the Camry's tranny is that it's slow to downshift all the way (it's like a two step process). But once it does, it's pretty strong for a V6.
Old Jun 10, 2007 | 09:19 AM
jimmykce1's Avatar
I can get the new mustang V-6 (4L) all day long with my G. Also I was bumper to bumper with a mustang gt convertible, which surprised me since they are running 300HP and 320ft-Lbs. I know the convertible is also 200 pounds heavier than the coupe too.
Old Jun 10, 2007 | 10:46 AM
jiminy4DR6MT's Avatar
Haha, you're funny and also very wrong. Just because it has an open diff doesn't mean it's going to peg leg. My G can EASILY lay two patches of even rubber in 1st. Only when I gun it on a slippery surface or off camber turn will it peg leg a bit. The car is just as tail happy as my old Z28 with a torsen LSD.
to the know-it-all.
Just goin by what I see buddy. And I DONT see a lot of 5AT sedans layin down two trails of rubber, unless you know what you're doin behind the wheel. Which is sounds like you do.
Old Jun 10, 2007 | 12:05 PM
DaveB's Avatar
Originally Posted by jiminy4DR6MT
to the know-it-all.
Foot on brake, foot on gas, mash gas, release brake a 1 second later. It's not rocket science Chances it will yield a better 60' time than 90% of the 6MT drivers out there too.
Old Jun 10, 2007 | 12:29 PM
g35sedan5at's Avatar
i drive an 06 5AT with lsd and i dont think ive ever NOT layed down 2 patches or rubber. of course the right spins first but by then the lsd has engaged both wheels and im up up, and away!
Old Jun 10, 2007 | 02:31 PM
OCG35's Avatar
Originally Posted by Pearlcoupeg35
automatic g sedan isnt a tire-lighter by any means
hmm... you sure about that?...
Old Jun 10, 2007 | 04:12 PM
Pska's Avatar
my 6MT can peel out through 3rd if I REALLY wanted it to...
Old Jun 10, 2007 | 04:36 PM
DaveB's Avatar
But how long would the clutch last or would it stick to the floor... My 90 CRX Si would bark the tires into 3rd. It was a low 16 second car
Old Jun 11, 2007 | 02:24 PM
ttrank's Avatar
Grocery getter
I don't have a problem loosing traction with 275/30/20’s on the back.
The OEM wheels are like trying to drive on wet roads most of the time.
Just keep adding boost until the desired result is obtained.
Old Jun 11, 2007 | 03:05 PM
Jeff92se's Avatar
Red Card Crew
Welded diff = broken crap all over the road.
Old Jun 11, 2007 | 03:31 PM
  #30
FenixL1P's Avatar
i can light my tires up with the vdc off and they are the M35/45 sport 19's...
