Why doesn't 260hp/260tq light up tires more easily?
Originally Posted by sly1types
The most important factor our autos don't spin, is the first gear is really tall or the rear end is to tall. If i floor it, it doesn't do much untill 3k then it really starts to pull at 4k.
Originally Posted by DP03
No one gives the 268 hp Camry respect on this board. Fact is, it will smoke the G (its 6 speed tranny is the key) unless it's a VERY talented 6M driver (like it or not, there are not that many out there
).If you believe the new V6 Camry will "smoke the G", then maybe... well, I honestly I don't know what to say.
Driving under the influence can be a very deceptive
I will give the V6 Camry credit for being fast for what it is, but it will not smoke any G. It might smoke the driver... but not the G.
It can keep up though... until you hit the twisties.
Dave, I respect your opinion. Maybe I just came accross bad drivers while driving the wife's car.........the one thing I don't like about the Camry's tranny is that it's slow to downshift all the way (it's like a two step process). But once it does, it's pretty strong for a V6.
Anyone that's having trouble, here's an acid test. Stop on an incline, turn of VDC, put it in neutral, rev engine to 4-5K, foot off the brake so you start rolling backwards slowly, pop it into drive and floor it in one motion.
Haven't done that in the G but worked for every other car I've owned, don't break anything!
Originally Posted by plutonium239
I'm sorry, I am 33 and this question seems very childish but seriously, with my auto 04 sedan and an open diff, in the dry when I nail the throttle from a dead stop, I would expect the rear tires to at least give a nice squeal, with or without the tracton on.
Guest
Posts: n/a
5AT of course you can....
1. do what daveb says; turn VDC off ...brake, throttle let er rip, play with the brake for a longer burn time.
2. admire the twin black lines....
I had my car in the dealer yesterday ...just saying...my foot slipped... a few times... oops.
Originally Posted by OCG35
brake + throttle at the same time cuts power on my car (even with VDC off)... I haven't yet pulled fuse, or plug... I would veture to say my car is not unique - so it's likely that your car will do the same. If you think youare laying down rubber with this method I'm not sure you are understanding what your car is doing... take it to a track and apply brake and throttle at the same time and see how long it takes the car to react.
The ECU definitely cuts power when both the brake and throttle are applied, but it doesn't seem to limit the car's ability to spin the tires. I'd love to figure out how to get rid of the ECU nanny because I know this car could launch far harder. I really don't even know why Nissan put this into the design.
Hasanbaloch
Feb 29, 2024 08:45 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
