Trunk Interior Pull Handle
Old Jun 12, 2007 | 12:29 AM
G35Dreamz's Avatar
I took off the inside black plastic pull handle in the trunk and it won't stay back on. Is there something that i might of broken preventing it from staying secure?
Old Jun 12, 2007 | 01:46 AM
psedog's Avatar
Back in SD**
Check the metal clips. Make sure that they aren't completely flat. If they are use a flat head to pull them back out. Also check the sheet metal of your trunk as that is pliable also. Good luck
Old Jun 12, 2007 | 05:58 PM
MEXTEP's Avatar
I have to keep that always functioning..you know, for when family visits from Mexico.
Old Jun 12, 2007 | 08:54 PM
ttrank's Avatar
Grocery getter
Mine never stays either.
Old Jun 12, 2007 | 09:44 PM
maliy06's Avatar
on my i just have to push it in hard so that it clips in, and it stays in good.
Old Jun 13, 2007 | 12:08 AM
G35Dreamz's Avatar
I think i broke the clips then.. The only metal clip i felt was on the left side of the inside. Nothing clips onto the metal clip. I think i broke the tabs on the black handle then. When you remove the handle, do you pull to the right or straight out?
Old Jun 13, 2007 | 12:30 AM
psedog's Avatar
Back in SD**
When I removed mine, I used a flat head screw driver to bend the metal tabs in.
Old Jun 13, 2007 | 12:39 AM
psedog's Avatar
Back in SD**
Here is what mine looks like, I just pulled it off with a putty knife, way bleepin' easier.
All the scrapes are from the first time I pulled it off, I couldn't find the flipping tabs.
Hope this helps you.
Old Jun 13, 2007 | 01:52 AM
G35Dreamz's Avatar
Pictures are worth a thousand words! Thanks!!! There aren't any clips on the black handle. I pulled it off one time and was able to put it back on. They must have fallen inside the trunk lid or something.
Old Jun 13, 2007 | 02:10 AM
psedog's Avatar
Back in SD**
Glad to have been of help. Good luck finding them.
Old Jun 13, 2007 | 04:31 AM
GixxerSteve's Avatar
I just installed an OEM spoiler on my 03 G35, and when I needed to remove the trunk lid liner to run the wiring, I had to take the black handle off. Came off easy, but took me much longer to put back on. Mine does not have the metal clips either, its just black plastic. I found out that I had been pushing on it so hard to get it to "snap" into place, that I had actually bent the inside of the trunk lid where it seats. So I used some pliers to pull the edges of the hole back out, then the black handle popped right back in.
Old Jun 13, 2007 | 07:55 AM
psedog's Avatar
Back in SD**
Maybe the different years use different handles? (03-04 vs. 05-06)
Old Jun 13, 2007 | 01:08 PM
G35Dreamz's Avatar
I think you are right. Mines an 03.5 so it doesn't have the metal clips. Good thing I didn't go looking for the metal clips.
Old Jun 13, 2007 | 03:40 PM
psedog's Avatar
Back in SD**
That would have been a hilarious outcome . 2 days later, I still can't find those fkn clips
jsimonk
Dec 22, 2023 03:49 PM
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
INVADER_6MT
Sep 1, 2015 10:19 PM
