Pulled Fenders
Old Jun 12, 2007 | 03:34 AM
VQ Hotness's Avatar
Pulled Fenders
Have any of you guys pulled your fenders ? I'm thinking about doing this.. I need to optimize my traction in the rear and adjusting my Camber will do that.
Old Jun 12, 2007 | 03:36 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
i was thinking of having a body shop do this for me so i can easily fit my 10" +40 wheels in there with still being able to have around -1.0 camber, not the -2.0 i have right now.
-GP-
Old Jun 12, 2007 | 03:49 AM
VQ Hotness's Avatar
I heard you can use the same tool you use to roll your fenders.. But you just keep on going after your fenders are rolled and it pushes the fender out.
Old Jun 12, 2007 | 03:51 AM
you could do that, but it would be pretty hard to get the crease out perfectly and it would take alot of heat and a looooong a$$ time.
-GP-
absolutg's Avatar
workin...
if you don't change the camber and just go with wider tires in the back, you'll actually lose some traction. equivalent weight spread out over a greater surface area equals less pounds per inch of downward force.
Old Jun 12, 2007 | 03:58 AM
GreenGoblin's Avatar
The goblin resurrection
i beleve it is westwood? that sells a tool that does it bolts to your caliber and you run it on the inside of you fender
Old Jun 12, 2007 | 03:26 PM
Vinny@VTR's Avatar
thats just to roll it with... to pull is a whole different thing...
Old Jun 12, 2007 | 06:17 PM
ttrank's Avatar
Grocery getter
-GP-
I had +40's on my rear with approx -0.6 camber and no rubbing issues even with three people in the back seat and bags in the trunk tucking past the top of the rim.
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
DRG35R
Jan 31, 2016 07:14 AM
alexbenz
Sep 26, 2015 11:30 AM
