245 tires + z/coupe springs = rubadubdub?
Old Jun 15, 2007 | 04:08 PM
infocalypse's Avatar
Question 245 tires + z/coupe springs = rubadubdub?
Hey peeps.
I've been digging through forum searches for a while and I've yet to find a clear answer on this one, hopefully you can help. I'm about to drop my 05 sedan (sport model w/OEM 18" wheels) with the z/coupe spring combo and some d-specs. My stock tires are in dire need of replacement and the tires I've to decided to replace them with (General UHP's) don't come in the wanked 235/45 OEM size.
My question is this - If move up to 245/40 tires on the stock wheels and drop the car with the z/coupe springs, will I risk any rubbing? (i suspect 245/45 would look too "tall" and risk rubbing further) Have any of you implemented this combo?
Old Jun 15, 2007 | 04:10 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
You will not rub with 245/40 tires. I ran the same setup on my car.
-GP-
Old Jun 15, 2007 | 04:15 PM
Awesome, thank you!
Old Jun 15, 2007 | 06:16 PM
sloppymax's Avatar
i have a set of 245/45 that i got a great deal on that i am mounting on 18" OZ wheels this weekend. i dropped it a few weekends back on z springs all around. it appears that there will still be plenty of room/gap that rubbing will not be an issue. i will report back if otherwise is proven.
Old Jun 15, 2007 | 06:17 PM
(>")> G35's Avatar
Depends on the offset, but since your using the stock 18"s, it will not rub with it's conservative offset.
Old Jun 15, 2007 | 06:22 PM
+1, it wont rub unless you're running that size on something like coupe 18's with they're +30 offset on an 8" wide wheel.
-GP-
Old Jun 15, 2007 | 09:39 PM
obender66's Avatar
Look at my signature
Old Jun 16, 2007 | 01:39 PM
sloppymax's Avatar
-GP-
what would be your initial thoughts of a 35 offset on an 8" wheel?
Old Jun 17, 2007 | 01:45 PM
dklau33's Avatar
I have 245/45/17 on 17x8 +35 wheels, dropped a tad over an inch and not in danger of rubbing at all.
Old Jun 18, 2007 | 08:58 AM
ron4row2's Avatar
I have the 245/40 tires in the General UHP's with the Z/Coupe spring set-up for a 1 inch drop. You will be fine. I love the tires espically for the price.
Old Jun 18, 2007 | 11:29 AM
darnelled's Avatar
The offsets are key. Here are my 245-45-18 General UHP's on 18x8 rims with same drop as you. No rubbing, but close.
Old Jun 19, 2007 | 01:37 PM
FenixL1P's Avatar
i'm on M35/45 sport 19's with 245/40 with 350z springs all around and d-specs and i don't rub.... i've got 5mm spacers front and rear since M sport 19's are 50mm offset while stock sport 18's are 45mm offset...
paolojericho11
Sep 11, 2015 07:08 AM
linedr89
Aug 17, 2015 05:11 PM
cbax
Aug 17, 2015 07:41 AM
MyfistYourFace
Aug 8, 2015 11:58 AM
wuppiedog
Aug 7, 2015 11:16 AM
