Fogging up and winter driving
Old Jan 19, 2004 | 03:11 PM
gribblep's Avatar
Yesterday I posted a comment about G35 design flaws, and then read many comments about fogging up adding more credance to my own problems. I have just returned home after a snowy drive home in Cleveland Ohio with an outside temp of 16F. I tried all the advice given on these pages and was only successfull at keeping the fogging up under control when I ran the front defog full blast making the car feel like a sauna. Even under these conditions my rear defroster barely kept the rear window clean. I noticed most other cars on the highway seemed to have clear side and rear windows. This is a wonderful car to drive in the summer, much more tricky in the snow, but really disappointed that Nissan seems to have missed some of the details that make a car easy to live with.
Old Jan 19, 2004 | 03:53 PM
rajanb's Avatar
Re: Fogging up and winter driving
Just to confirm :
- you did have the FRESH AIR on (or RECIRC off)
- you had the AC on
And you still had fogging problems?
The fogging happened on windscree, front windows, rear windows ...?
I have not had any problem with fogging regardless of temperature and we were down to about 15 F here. However, it was very dry outside.
G35S AT / Ivory Pearl and Black
Old Jan 19, 2004 | 04:10 PM
gribblep's Avatar
Yes, I very rarely use recirc as it makes the problem worse, and yes AC was on . Problem much less on dry days, most of my problems are when it is raining or snowing. On my other cars I just set the control to auto and forget messing around.
Old Jan 19, 2004 | 04:17 PM
hooner67's Avatar
I 2nd that. Same problem. I'm @ Washington St.
Old Jan 19, 2004 | 07:13 PM
zorro's Avatar
gribblep, I noticed the same problem last summer. Then after playing around with controls, I was able to defog it in seconds. I can't remember exactly what I did, though.
It be great if someone, who had a similar problem and solved it, could post a response to this thread. I am sure it's just a matter of getting the right setting.
G35 Coupe. Diamond Graphite, Graphite, Premium and wheel and Tire package. Zaino Baby.
Old Jan 19, 2004 | 08:38 PM
ABQ_G35's Avatar
Okay, no one has asked this, but did you have any damp clothing, jacket, shoes, etc in the car? That happened to me once in my last car, had gotten some moisture on my jacket, I had a helluva time defogging the windows. Alos, the rear window defrost should help, do you use that?
Brilliant Silver/Graphite '04 Sedan/5AT
Old Jan 19, 2004 | 08:47 PM
gribblep's Avatar
Yes, I was pretty damp after scrapping the windows, but thats the same with any car. You are also correct, as last week I had two others in the car after running to the car in a snow storm, but wife in other car with one passenger seemed to have no problems. After the comments I am hearing I am becoming convinced that this is just poor engineering and something I never thought about when purchasing the car
Old Jan 19, 2004 | 09:05 PM
ABQ_G35's Avatar
How long have you had your G?
Old Jan 19, 2004 | 11:22 PM
gribblep's Avatar
Had the car since May, obviously the winter experience has dampened my initial enthusiasm.
Old Jan 20, 2004 | 11:35 AM
Gordgee's Avatar
Administrator
I've had my G for 2 winters now. No complaints about winter driving and fogging up here in Edmonton. The rear window defroster actually works better and faster than most cars I've had, mind you, I'm not sure if the tint helps or not.
<font color=green>GroundingGear™ Equipped </font color=green>
Old Jan 20, 2004 | 05:43 PM
hooner67's Avatar
I had mine since 04/02.
Old Jan 20, 2004 | 09:00 PM
skeleton_cru's Avatar
Sedan
I noticed that my G fogs up more then any previous vehicle I have had too. A few things that might help. 1) make sure that your windows are kept very clean. Use a good quality window cleaner. 2) try an anti fog treatment like Fog-X. It won't eliminate fogging but should minimize it. 3) turn your defroster on before the fogging even starts, be proactive. If the weather conditions hint at possible fogging of the windsheild I just put my defroster on low and find a comfy temp. The drawbacks are you use more fuel and lose some HP 'cause the A/C is running. But it's better then driving blind.
...Skeleton Cru
Old Jan 20, 2004 | 10:35 PM
ABQ_G35's Avatar
Well, for a change, we had a very damp day today here, I was out in rain and some snow, and I had absolutely no trouble with my windows fogging up, there was a hint of it on the windshield when I started the car one time, but it disappeared before I could turn the defrost on! So, guess mine is fine!
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
Freddy07g35
Sep 17, 2015 08:53 PM
bjo16
Aug 4, 2015 09:52 AM
Kal Hamm
Jul 24, 2015 08:55 AM
