Clicking noise from A/C
Old Jul 26, 2014 | 04:26 PM
bthornic's Avatar
I found it, but there was nothing in there. Looks like i'll need to replace my recirculation actuator. Does anyone have a link to a guide on how to replace this or at least where it is located? I've read that you have to remove the dash.
Old Oct 20, 2014 | 02:04 PM
psedog's Avatar
Back in SD**
You would definitely have to remove the lower section of the passenger side of the dash. I doubt you would have to remove the rest, but I haven't checked into it. Did you figure it out?
Old Oct 21, 2014 | 08:48 PM
bthornic's Avatar
Problem solved
I managed to fix it really easily. The air filter was just bent so the vent door was getting jammed on it. I just had to take the bottom panel off to get to it. I think the filter was upside down too, so i just flattened out the bend and flipped it the right way up.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
