rear valve stemp core over-tightened
Old Aug 10, 2007 | 02:47 PM
ballerina's Avatar
Hi, thank you so much for all the suggestion for tires. I just got new tires installed on my car at Costco. They left a note saying "the right rear valve stemp core over-tightened". The service person said "he didn't want to try to remove it b'coz if it breaks, they will have to pay for it".
What is the right rear valve stem core? How does it get overtightened? how much does this cost to replace? My car has 30k miles and this is the first time the tires are replaced. I am thinking of taking the car to the dealer tomorrow, so they will take a look at it. How much cost am I look at here? What are my options if this ends up being an expensive repair. Surely, I never touched the thing and I don't know if it's losened/tightened at the time of tire roatations.
Really appreciate your input. Thanks.
Old Aug 10, 2007 | 07:19 PM
ttrank's Avatar
Grocery getter
I think he means Valve Stem Core. It is the screw-in center of the valve stem and is cheap. I don't know why they care if it breaks.
Old Aug 10, 2007 | 09:05 PM
Curt G's Avatar
Maybe if it breaks in the valve stem then the whole TPMS unit would have to be replaced.
Oh, and for ballerina, the valve stem core is the actual valve that holds the air in. They usually replace the whole valve stem (that's the part that sticks out of the rim to add air to) when they change a tire, but since ours are solid metal they just replace the inside part.
Old Aug 11, 2007 | 08:21 AM
thelurker29's Avatar
right the valve stem is a little tiny metal device that costs like 5 cents hehe but of course if that breaks inside the SENSOR which we have then they will have to figure out a way to remove it without damaging the sensor i bet they were just being sensitive and scared to do it..so if you can get a hold of a new valve core and the tool needed just remove it really really slowly yourself..unless you too find that it IS too tight...
Muski_G
Dec 1, 2023 11:11 AM
Greg Huston
Sep 25, 2016 11:36 PM
yassy
Aug 9, 2015 07:31 PM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
lemmy999
Jul 25, 2015 12:13 PM
