How can i run STAGGERED on an AWD sedan
Old Aug 12, 2007 | 03:29 AM
  #31
iiiiiekoiiiii's Avatar
im prbbly gonna pull the fuse, let the warrant actually be good for something if it comes down to that =]
Old Aug 12, 2007 | 03:38 AM
  #32
Garnet Canuck's Avatar
Traveling Administrator
Originally Posted by STOOF
hey man run the staggered.
worst case you blow the TC. put your stockers back on bring it in for warranty
Wow, great advice!
Old Aug 12, 2007 | 10:32 PM
  #33
Mustang5L5's Avatar
I'm a little confused.
By staggered, do you mean tires with different heights (like 19" wheels in back and 18's up front) or tires with different widths? (8" up front, 10.5" out back)
If it's widths, how does the car know? Does it have to do with the weight and rolling resistance of each wheel??
I can understand how different diameter wheels would screw it up. A lot of cars have their ABS messed up with different diameter wheels. I know when i go racing at the track with large wheels with Slicks inthe rear i need to pull the ABS fuse because it plays hell with the ABS/traction control.
But if it's different widths, could someone enligten me as to how different sized contact patches and slight weight difference would mess up the AWD??
Old Aug 12, 2007 | 11:31 PM
  #34
Neal376's Avatar
lol - your correct it wont.
it is more about diameter really
the problem is finding rear tires that will have the same height as your thinner front wheels. the thing is that the AWD could handle a certain difference - but not too much i.e. running slicks in the rear would really **** off your AWD but just running 10inch wheels in the rear with similar diameters wont really do much harm...it might however cause alot of wear and tear if you drive the car at high speeds through tight corners but ATTESA should accommodate for that (not a locked diff)
Old Aug 13, 2007 | 01:03 AM
  #35
i pulled my AWD fuse off today and attempted a little burn out. It didnt work out =[ First i heard the rear spin, then stops it around 2-3K rpms and rpms wont go up with or witout vsd lol, I put my fuse back on and enjoyed the pick up off the car with 4 wheels rwd or fwd cant jump like that =]
Old Aug 13, 2007 | 07:29 AM
  #36
Mustang5L5's Avatar
That makes much more sense lol
Old Jan 1, 2008 | 02:54 PM
  #37
oooooooooooooq's Avatar
Im pretty sure that the 911 c4 has a staggered setup. so if the germans can doit, so can you.
Old Jan 1, 2008 | 09:31 PM
  #38
seddon's Avatar
Look people I have 245/35 in front 275/30 in the rear the rolling diameter is pretty close. I drove with the fuse in for about 1k miles and no problems. The Infinti AWD sysytem is not the greatest and if the Germans can do it so can we.
Old Jan 2, 2008 | 12:00 AM
  #39
Thats what im talkin about seddon,
Ima run the Same Set up lol cant wait till spring its gonna be hard choosen wheels.
I was gonna run 275/35 in the back do u rub wit the drop?
U stay In BX ill stay in BK. only red sedans lol
Old Jan 2, 2008 | 01:18 AM
  #40
VQ Hotness's Avatar
ooooooooooooooooq is the king of reviving dead threads.
Old Jan 2, 2008 | 09:22 AM
  #41
its because i LOVE to search.
Old May 13, 2008 | 09:40 PM
  #42
Sacch's Avatar
So in conclusion...
we can run a staggered set up on the X if the circumference of the TIRES are the same.
Am i right?
  #43
Sacch's Avatar
So in conclusion...
Am i right?
Old May 13, 2008 | 11:35 PM
  #44
FutureGDriver's Avatar
i have two weeks with the fuse in running staggered and on highway on my way to work and it handles fine with no problem at any speed...it feels like i have my factory wheels on. .... thanks to SEDDON for the information on his staggered setup
Old May 13, 2008 | 11:51 PM
  #45
Sacch's Avatar
keeep me posted, i wanna go staggered!!
