fuse box question
Old Feb 4, 2004 | 12:00 AM
arkgold's Avatar
fuse box question
I hope you, guys, can help me. Just picked up my new G35x. Totally gorgeous, except for one little problem. The turn indicator/hazard arrows don't light up on the dash. If I am not mistaken a fuse is out. The manual refers to a fuse box in the "passanger compartment", but no matter how much I tried I couldn't find it. Any of you know where it might be located?
Thanks.
Old Feb 4, 2004 | 07:54 AM
cato's Avatar
SouthernComfort Moderator
Re: fuse box question
Take it back to the dealer. Problem solved!
2003 Twilight Blue 5AT Sedan, sunroof,
Graphite Leather, splashguards,
12 wire Hyper-grounding kit,
350Z intake duct, Stillen Hi-Flow Airbox
Underbody rear diffusers, Drilled aluminum pedals
Old Feb 4, 2004 | 11:06 AM
ryoken's Avatar
The fuse box in the engine bay is hiding in the battery compartment.
The fuse box in the passenger compartment is hiding behind the parking brake pedal (or clutch, as the case may be) on the left wall in the driver's foot well.
Old Feb 5, 2004 | 05:02 PM
arkgold's Avatar
Thanks a lot! Luckily I didn't try to fix it myself, as the problem turned out to be deeper than I thought. The lesson I learned, make sure your dealer preps the car well before you pick it up.
Thanks again.
Old Feb 5, 2004 | 05:22 PM
ryoken's Avatar
So, what was the problem, then?
mtlruss
Dec 20, 2015 01:51 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
Fireman07603
Aug 9, 2015 06:00 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
.cakestar
Jul 28, 2015 01:57 PM
