oem bose stereo
oem bose stereo
does anyone else have this problem?
whenever i play a cd, the sounds are not equal, meaning all the sounds transfer to the right side, and there are no sounds from the left side.
this happens at any time there is a slight bump in the road, so then whenever i hit another bump, the sounds become equal again.
i know its not a problem with the speakers because FM works fine..
i was thinking it could be mechanical in aspect, maybe the lens needs cleaning.. so then i tried playing a lens cleaner and i get "disc error"
YIKES
YIKES
YIKES
YIKES
Very f*ing annoying. My G35 doesn't do this.
Just posted about this a couple of weeks ago.The problem is the cd player itself.Mine was replaced at that time under warranty and all is good (for) now.
Hate to disappoint you but Bose outsourced the manufacturing of these units to Clairion!! Supposed to be made to Bose specs but Clairion cut back on the laser that reads the disc.This is a common issue with Clairions own units.
Ticks me off.Kind of like buying a Rolex and you find out it was made by Timex.
The problem with the left speakers cutting out while playing CDs is a common problem with the BOSE Nissan/Infiniti radios. The problem is in the head unit. It happens to Nissan/Infiniti decks with tape + 6-CD combo. There's a solder joint problem on the PCB that has the audio processor chip on it. Finding the bad solder joint is not easy since the problem will come & go whenever it wants to. The best (and easiest) solution is to get the head unit replaced. Even then, the problem will probably occur again with the new head unit, because they're still designed the same way.
Lots of experiences like this with the FX. Here's a discussion on Infinitifx.org http://www.infinitifx.org//phpBB2/vi...c.php?p=166699
