Easily the best thread on g35driver, kudos bythebay...you're a class act.
I kinda wish I lived in SF so I could be a part of the DIY series.
I would really love to see an ATF flush//change. I hope you find the time bythebay. You rock
By the way bythebay, what pump is that you used on the diff change?
.By the way bythebay, what pump is that you used on the diff change?
Quote:
By the way bythabay, what pump is that you used on the diff change?
I have an MT so I can't do one, however, erdog in my area wanted to do a flush on his AT so maybe at some point I'll have that up.Originally Posted by JarjarXG
.By the way bythabay, what pump is that you used on the diff change?
As for which pump I used, it was the Amsoil hand pump for bottles.
Thanks man.
If only you weren't "bythabay", it'd be nice if you were "by L.A."
Great vids man! This really helps a DIY noob such as myself.
With saying that...I have a question regarding the brake bleeding process. 1) What was that noise in the background as you opened the valves? Was were you pumping the pressure back to 15? 2) What was the purpose of marking how much fluid was in the bottle? 3) I've been told it's better to put a little fluid in the bottom of the waste bottle to prevent air from being sucked in?
Thanks very much for your response! I look forward to more of your vids!
Ryan
Ryan
Ryan
Yeah, the noise was one of the other guys keeping the pressure up at 15psi. The marking on the brake fluid container was so that I'd know when I had passed through 1/4 of the fluid. As for air being sucked in.. well, look at it this way: The system is pressurized (15psi) so when I open a bleed screw, the fluid will come out, so no air coming in. When I'm done bleeding from that screw, fluid is still coming/pushing its way out at a nearly constant 15psi, so shutting off the valve does not allow for air to enter.Originally Posted by Infinite1
Great vids man! This really helps a DIY noob such as myself.With saying that...I have a question regarding the brake bleeding process. 1) What was that noise in the background as you opened the valves? Was were you pumping the pressure back to 15? 2) What was the purpose of marking how much fluid was in the bottle? 3) I've been told it's better to put a little fluid in the bottom of the waste bottle to prevent air from being sucked in?
Ryan
more vids on the way
Just replaced my In-Cabin Air Filter with the charcoal one.
It took all of 4 minutes thanks to this video...yanked off some plastic, unscrewed some screws...the ol' switcheroo and reassemble...
The air is squeaky clean and saved a whole bunch of money.
Thanks a bunch for the DIY Eugene
Now for the oil change...
Quote:
I would make a vid for that if someone would invite me over for an install...Originally Posted by dranom
any DD conversion kit vids coming soon?
G35Papa
close
- Join DateJun 2003
- LocationNorCal
iTrader Positive Feedback100
iTrader Feedback Score(85)
Liked:451 Times in 305 Posts
Quote:
You never come out Originally Posted by bythabay
I don't blame you, we start early and its a drive for you.
At the end of the month, I'm finally doing my drive belts and we're doing another set of headlights (black out and clear turn signals).
I haven't been invited to a DD install yetOriginally Posted by G35papa
You never come out
G35Papa
close
- Join DateJun 2003
- LocationNorCal
We already did mine. I don't think we'll be tackling one for a while again. I'll let you know when we do.
