New problem .... slow acceleration
Old Oct 30, 2007 | 07:33 PM
RXM's Avatar
RXM
Hi all,
I'm sure most of you guys have read my previous post about loose plenum spacer bolts leading to lack of power and rough idle. The issue was fixed when I tightened all the bolts. Now I have a new issue.
My car started to experience slow acceleration recently. The car is still fast, but not as fast and when I gun it, the acceleration is slow. I'm going to present my case and I would like to hear everyone's thoughts on this. I tried doin an extensive search and most lead to throttle body issues, but I do not think this is the case.
Mods:
1. Plenum spacer
2. Grounding Gear
3. Z tube
4. Aftermarket air filter
5. HKS exhaust
Baseline readings/observations while in park:
1. Idle is constant at 600 rpm (this is usual for my car)
2. Car starts up fine
3. Exhaust sounds muted
4. Intake sounds somewhat lower sounding than normal (like it isn't sucking in the same amount of air)
Symptoms:
1. Slow acceleration (climbs slowly and does not throw me back into my seat like it used to on WOT)
2. Car exahust note does not sound the same (sounds mute - I have the HKS exhaust)
What I have done to try to correct symptoms:
1. Checked plenum bolts (all torqued appropriately) - Symptoms remain
2. Changed air filters (OEM, Amsoil, and K&N) - Symptoms remain
3. Cleaned MAF sensor with CRC MAF cleaner - Symptoms remain
4. ECU reset (multiple times different days) - Symptoms remain
5. Checked if some punk kid put something in my exhaust (negative) - symptoms remain
Confounding factors:
1. Brake, VDC, and Slip lights are on - could be due to the fact I need to get a brake change - scheduled to get it done this Friday
So, what do you guys think?
Old Oct 30, 2007 | 08:20 PM
sloppymax's Avatar
Originally Posted by RXM
Hi all,
Mods:
1. Plenum spacer
2. Grounding Gear
3. Z tube
5. HKS exhaust
Symptoms:
those lights will not come on when your brakes need replacing. they are illuminating due a failure which causes those three to kick on. if you have oem or similar pads, you will hear a low pad whirring noise when you are not on the brakes. there are no sensors on this car telling you when it is time to replaced either rotors or pads. when similar lights came on in my maxima, the alternator was starting to die. how long have those lights been on? have you noticed any dimming lights?
Old Oct 30, 2007 | 08:21 PM
Jeff92se's Avatar
Red Card Crew
Maybe if the pads are that low, the brake fluid gets low and trips those lights. I'd fix the pad problem and see if that corrects teh lights. Then see if the accerleration is still low.
Old Oct 30, 2007 | 08:48 PM
sloppymax's Avatar
I have seen the brake light come on for low fluid but I personally have not seen it trip any other lights.
Old Oct 30, 2007 | 09:30 PM
RXM's Avatar
RXM
From doing a search previously, people that reported those lights coming on had stated that their brakes needed to be replaced. The lights com on when your brake fluid is low. I think my brake fluid is just above minimum at the moment. Lights have been on for about a week. I am getting my car looked at this Friday to have the brakes changed.
Old Oct 31, 2007 | 12:47 AM
DaveB's Avatar
Did the power drop off when the lights came on?
And yes, worn pads can trip all those lights. It happened to my friend's 04 sedan with seriously worn pads.
Old Oct 31, 2007 | 07:07 AM
sloppymax's Avatar
good to know, i was not aware of that.
Old Oct 31, 2007 | 07:21 AM
RXM's Avatar
RXM
To be honest, I cannot say for sure if the performance drop occurred at the same time the lights came on...
I will definitely update the thread this Friday to let people know how it was resolved. I was hoping someone on the board would give me a heads up so I know what to expect going into the dealership.
Old Oct 31, 2007 | 08:08 AM
brianmfournier's Avatar
I can definitely tell that you are an Rx. You SOAPed the problem!
Old Oct 31, 2007 | 09:39 AM
birdman19's Avatar
I had the same problem about a week ago, took it to the dealership they called a tech out to look at it without even taking it into the bay, and he said it was due to low break pads. when the pads get low the fluid level in the resivor drops setting off the lights. I picked up the break pads while I was at the dealership and changed them over the wekend; lights are off and no problems now.
Old Oct 31, 2007 | 12:01 PM
SoCalTed's Avatar
If you have slow acceleration, the first couple of things to look at would be:
1) Air intake filter
2) Fuel filter
3) Spark Plugs (can also tell you if your gas is bad, or you are running rich/lean)
4) Something stuck in the exhaust (broken cat brick?)
after that it can be a variety of things...including low voltage, bad coil pack, weak fuel pump, plugged/obstructed gas tank, throttle body, ECU or perhaps a bad cylinder or two.
Old Oct 31, 2007 | 12:51 PM
RXM's Avatar
RXM
Interesting that you picked up on that. SOAP format is where it is at
Old Oct 31, 2007 | 01:03 PM
jimmyc13's Avatar
Damn, that sucks that you're still having this issue. Good luck with getting it fixed!
Old Nov 4, 2007 | 09:44 PM
RXM's Avatar
RXM
Update: I just wanted to update this thread with the resolution so that anyone else that experiences a similiar problem has an idea what is going on.
VDC + SLIP + Brake = low brake pad left (my rear pads were almost non-existant)
Slow acceleration + 200 miles/tank = The Infiniti tech stated that my Air/fuel ratio was WAYYY out of spec (no idea why) and was dumping a ton of gas into the engine. He replaced the throttle body, air filter (changed from Amsoil to stock), and I think he also replaced the MAF sensor. Car is now running the way that it used to
Old Nov 5, 2007 | 07:05 AM
sloppymax's Avatar
how did they state they tested the a/f? to my knowledge, the consult 2 only has short & long term fuels trims and does not have the ability to monitor a/f. glad its back to normal though.
