Weight reduction (need help)
#31
Originally Posted by maximumvette
I was just thinking the same thing as far as reducing weight. I was thinking starting with a light weight battery first. Not sure on the make as I'm still looking into it.
Yes they do and that is a good place to loose some weight.
These are one of the best.
http://www.brailleauto.com/productca...p?idCategory=2
#33
Not sure if we have steel or aluminum driveshafts but if we have steel this might be a good option. Thanks ttrank for the link,, didn't know about them.
http://www.stangpro.com/html/articles/driveshaft.htm
#34
#35
Originally Posted by RANC3R
whats the whole point of a sedan with no backseats? do u like the way the car looks? or the fact that its 3" longer and bigger? if you wanted a race car you bought the wrong whip son. sorry to hear about what happened today maybe youll get a nismo front bumper through insurance.. gl
#38
#39
#40
Originally Posted by M@rCo
right....because im sure you think the coupe is 10 times faster than the sedan right?
In general, the stuff fsas wants to do with his car makes no sense, considering he coulda just bought a 350z... no rear seats, lighter, faster, better handling
#41
#42
is there any modification needed to fit the coupe mid pipe or 350z mid pipe on a 05 sedan? no extension or anything?
#44
I bought my 04 sedan with a set of 17" kosei k1's. They are the same size and offset as stock 17's (17x7 +45mm offset). They weigh 14lbs, so that right there is a huge difference.
Kosei's are on the cheaper side, I would look into them if I were you.
#45
I've seen coupes reduce weight and end up under 3000 lbs. That would be a significant benefit in performance, especially since the sedan is lighter to begin with.
