Why is AC always on!?
on
Originally Posted by Gilley
People with fogged windows in the winter don't have a car as smart as the G.
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
yeah i always wonder as well, the first day i got my G, whomever owned it before me, left it on full blast A/C, I later realize I wasn't getting hot air at 35 degree, but cold a/c air.
Originally Posted by ttrank
I hate that fact about the recirc air on the G. Stupid idea from a company who makes cars for high humidity and cold areas. ![Roll Eyes (Sarcastic)](https://g35driver.com/forums/images/smilies/rolleyes.gif)
![Mad](https://g35driver.com/forums/images/smilies/mad.gif)
also
I don't need to spend major bucks on extra gas or listen to the damn loud *** fans running to deal with smogged windows. Once you figure out how to turn the A/c off(which took me about 10 pokes at the ac button while trying to use the heater on auto) try using the heater on manual or other wise while trying to circulate air from inside the car (you know the warmer air?) instead of outdise sub 30 degree air...........impossible, can't be done. It's just another long list of BS this car has made me generate. Never again, as soon as I get some equity this puppy is gone!!!!!!!!
Some of you guys are under the misconception that just because the A/C light is on, that the compressor is in use and it's cooling the incoming air. The compressor has a clutch in it that disengages when cold air is not needed. If the climate control system is set to a higher temperature than the temp sensor detects, then it's warming the air and the compressor is not running... so it's not wasting gas at all.
what kind of loser doesnt want to drive a g?
