G35 & G35x performance???
Old Feb 29, 2004 | 02:15 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Currently trying to decide which way to go.
The benefits of the X for winter driving are appealing yet....
I'm not sure if I want to take the performance hit with the extra weight.
Anyone seen any performance comparsons between the two.
Old Feb 29, 2004 | 02:59 PM
R2 V35's Avatar
Re: G35 & G35x performance???
The way I see it, AWD will really help you out in the Winter, snow..etc....AWD system was designed for that purpose.. As far as the comparison between the 2 G, I will go for the 6mt. That'll save you some cash and weigth...
6MT Ivory/Willow>>Nismo OEM Kit>>Premium Package>>XM
"Tell all my people i'm a Ridah, Nobody cries when we die, we outlaws, let me ride"
Old Feb 29, 2004 | 04:52 PM
Xman's Avatar
There was a post I think a month ago. Someone found in Autoweek. I think 0-60 times were the same. Can't remember the 1/4 times. Do a search. I live in a hilly area and get a good amount of snow so I opted for the X.
2K4 G35x/Brilliant Silver/Graphite/Premium/Wood
Stillen Hi-Flow/ Z tube/ Ground Kit
Old Mar 1, 2004 | 11:47 AM
dnapoli's Avatar
X-Man is correct. The numbers were the same even with the extra 300 lbs. It depends on your preferences concerning sport and luxury. First, you can't get the X in a 6 speed. Second, you can't get the Sport Package (stiffer suspension). Today I got a loaner car from Infiniti (3000 mile oil change). It drives just like the X. The advantage to having the X is definitely the AWD. It really kicks butt in the snow. I also noticed if you are waiting to make a turn at a stop light and have to get going, a rear wheel car can spin the tires easily. When I'm waiting to make a turn and I have to get across the street quickly the front wheels grab and send the car across the street in a blink of an eye. Note: I almost always drive with the VCD turned off.
If it's a G it's 4 me!
2004 G35x
Diamond Graphite~Graphite~Premium~Wood~Splash Guards~7 Wire Grounding Kit~Z-Tube
Old Mar 1, 2004 | 12:35 PM
InTgr8r's Avatar
thanks guys.. I'm leaning to the x, especially since I have to
go with the auto trany due to a bum left knee....
I had heard that times were similar, but was concerned that likely means gearing has changed.
Has anyone noticed if the x runs out of pull in the top end?
How is highway cruising at higher revs.
It just doesn't seem logical that you could add 300 pounds without some sacrifices.
Old Mar 1, 2004 | 04:53 PM
dklau33's Avatar
The AWD is good for launches since it has more intial grip, but will be more of a hinderance at high speeds. So maybe that is why the G35x and the regular auto has the same or similar 0-60 times. The added weight of 300 lbs. is offset by the fact that the 'x' gets better tracation at the launch.
04' G35S 6MT Ivory Pearl, Willow, Premium
Old Mar 1, 2004 | 05:58 PM
SteinerG35x's Avatar
Yes I also can feel and know about the great launch's the X has. An Acura Integra Type-R (ricey) car pulled next to me at the bottom of a hill and when the light changed, all he did was spin his tires, and my X was gone, no tire spin. I love the X, as I'm frequently up in the mountains getting my skiing on..
Steiner
2004 G35x Sedan | Brilliant Silver |
19' Moda R6's | Nav | Euro Package |
Clear Corners | Headrest TV's |
XBOX | DVD | Tint
http://www.kevinandjennifersweb.com/g35x.htm
Old Mar 1, 2004 | 09:09 PM
dnapoli's Avatar
The G35x pulls hard into triple figures. Hell of a lot faster then my BMW 323i did. The car is most comfortable driving at 80 MPH on the highway. I think it gets it’s best gas mileage at that speed too.
2004 G35x
Old Mar 1, 2004 | 09:38 PM
Xman's Avatar
Interesting, I have to try that VCD turned off eh?
Old Mar 3, 2004 | 10:43 AM
stsurbrook's Avatar
dnapoli,
I thought the G35x came with the sport suspension as its only option?
Scott
Old Mar 3, 2004 | 11:08 AM
dklau33's Avatar
Nope, the X's only come with the regular suspension. I'm sure one could swap it out with the sport suspension parts though if they wanted to.
Old Mar 4, 2004 | 12:00 AM
ekaz's Avatar
The front suspension is different due to the AWD so if I remember correctly, the sport suspension will not fit.
Old Mar 4, 2004 | 01:28 PM
Marty's Avatar
Two things: the sport suspension will not fit, because the X front suspension is from the FX. Also, no fit for current aftermarket parts, until they make them specifically for the X; second, the suspension on the X is slightly stiffer than the AT sedan, because they put in bigger sway bars and stiffer suspension bits to handle the additional weight. I had felt that the AT suspension was a little soft, with too much body roll and the sport suspension cornered flat, but you could feel every road imperfection. I was planning on putting in sways, but when I got my X, I found the suspension to be right in-between the AT and the SS; just about perfect.
Old Mar 5, 2004 | 01:11 PM
InTgr8r's Avatar
back to performance.........
here is a link to some data
http://www.g-owners.com/pictures_ima...statistics.xls
Old Mar 8, 2004 | 12:07 PM
pelucidor's Avatar
Buy the April copy of Automobile magazine (the one with the three ugly concept SUVs on the cover). They have a great comparison of the G35S 5AT vs the G35x in the guise of discussing the value of AWD cars and cover every performance number (under good and bad traction conditions) back-to-back, and the G35x does very well. If you want I can type up the numbers for you this evening...
'04 G35 Sedan 6MT in Diamond Graphite/Graphite with Premium, Nav, Aero
'02 Acura MDX Touring in Redrock Pearl/Saddle with wood bits, cargo stuff
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
kinetek
Aug 3, 2015 04:25 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
simperformance
Jul 24, 2015 11:17 AM
