40000 mile service
Old Dec 9, 2007 | 08:56 PM
04-6speed-sedan's Avatar
40000 mile service
i have an 04 6 speed sedan and was wondering when to change the tranny fluid.......
Old Dec 10, 2007 | 12:19 AM
lexusk8's Avatar
It should be every 2 years or 30K miles, whichever comes first.
Old Dec 10, 2007 | 11:22 AM
canucklehead's Avatar
i changed mine at about 55K kms, along w/ the diff. you should change these fluids during the 40k service. you don't have to get it done at the dealer. they charge far too much $$ for these simple procedures. a quick-lube shop can do it for 1/2 price using synthetic fluids.
Old Dec 10, 2007 | 11:32 AM
Yv12345vY's Avatar
Your timing is a bit off I think. 40k miles is closest to 37,500mi service, which is just an oil change :-) If it's a car you just got used then might as well play it safe and change the tranny fluid. Otherwise I'd wait for 60k.
Old Dec 10, 2007 | 11:42 AM
Gilley's Avatar
According to the maintenance schedule, AT fluid doesn't need changing until at least 60K miles. http://x.infinitihelp.com/maintenance/
Only use Nissan Matic J AT fluid.
Old Dec 10, 2007 | 01:50 PM
G35m@'s Avatar
+1......Use the J-Matic
Old Dec 10, 2007 | 03:23 PM
Gilley's Avatar
^ That's what I meant. LOL
Old Dec 10, 2007 | 09:23 PM
BuckeyeG's Avatar
HEs got a 6 speed MT
Old Dec 10, 2007 | 10:01 PM
Joe_Camel's Avatar
Manuals don't have transmission fluid, they have very thick oil... you should inspect/replace your transmission oil every 30K.
Old Dec 10, 2007 | 11:25 PM
Gilley's Avatar
Duh!! I don't know what I was thinking. Brain fart. Don't use J Matic fluid in your 6MT.
The 6MT requires GL-4 gear lube.
Last edited by Gilley; Dec 11, 2007 at 12:11 PM. Reason: I didn't do my own research before posting.
Old Dec 11, 2007 | 10:58 AM
The 6MT requires GL-4 gear lube. Somewhere in a TSB it states something that using anything other then Nissan manual tranny fluid will void the tranny warranty, but I couldn't find it in my quick search.
^ i believe the requirement is to use either Nissan tranny fluid or a compatible alternative. i.e. a GL-4 type lubricant that meets or exceeds the applicable standards. it doesn't have to be exclusively Nissan lube though.
there are several other good GL-4's on the market that will work in addition to Nissan MT lube.
Old Dec 11, 2007 | 12:14 PM
Gilley's Avatar
I didn't do my own research when I made the above post and corrected it. What I read was out of context and was a statement that using any MT oil other than Nissan would void the warranty. The statement really says the dealers will only be reimbursed for Nissan MT oil when doing warranty work.
2001-2004 ALL NISSAN: MANUAL TRANSMISSION OIL
REQUIRED FOR WARRANTY REPAIRS
Applied vehicles: 2001-2003 All Models Equipped with Manual Transmission
2004 Maxima (A34) - All Models Equipped with Manual Transmission
Service Information
If an Applied Vehicle eqiupped with Manual Transmission needs servicing for warranty repairs, Nissan Manual Transmission Fluid (MTF) HQ Multi 75W-85 oil
(P/N 999MP-MTF00P) is required.
Important Note: Nissan MTF HQ Multi 75W-85 oil must be used when performing manual transmission repairs paid by Nissan. These include warranty, service contact, or goodwill repairs. Nissan will not reimburse dealers for manual transmission repairs when Nissan MTF HQ Multi 75W-85 oil is not used.
If a manual transmission requires the oil be drained for maintenance or repair (customer pay work), 75W-85 oil is required as the service fill fluid.
Nissan recommends use of MTF HQ Multi 75W-85 oil, which optimizes shift quality, for customer pay use as well.
derres
Aug 28, 2015 03:27 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
wuppiedog
Aug 7, 2015 11:16 AM
mjfenix
Jul 17, 2015 02:07 PM
newbdriver01
Jul 15, 2015 06:10 PM
