Headlight work - Matte black and cleared
#125
Chris is right about the ebay "replacement" lenses but mine are not yellowing..they are however starting to flake on one of them. They will fit in terms of going back onto your OEM headlight base but they do NOT sit all the way down (don't clip into all clips) so I had to use a some silicone to make sure I had a good seal. Without using the silicone...condensation set in.
IMO...stay away from them....OEM halogens is the best replacement. If you have HIDs, just re-use the bezeles and lenses from the OEM halogens ones. The quality of the ebay lenses and brezels is just not up to par with OEM. They have small imperfections all around them....at least the ones I got did. Clear bra is a great idea.
#127
Afordable: Either wetsand and use a buffer to polish them up real good (what I did today, came out amazing).
More Expensive: Get some halogen OEM headlights off ebay with lenses in decent-good condition and replace. OEM is the only way to go in my opinion. Plus you could use them for parts. AKA paint the bezels black and swap them out to see if you like the look. If not, swap the stock/chrome ones back in
#128
#129
take a look at this... the lights look like this ones...
http://www.sabersport.com/Merchant2/...H-IG35B-KS.jpg
#131
i know its gone over a hundred times what paint you used, duplicolor bumper paint....buuuuttt, the title of this thread says cleared, unlike your own personal lights which you did not clear. do you mind telling me which clear was used on these lights? also, compaing pics from your headlight thread to these they look pretty much identical as far as color goes, are they different in person due to the clear?
#132
#133
