Heated Seats infiniti 53.00 option
Old Jan 23, 2008 | 04:12 PM
03Sg35's Avatar
I would check for the plugs before i buy the switches, all you need to do is take the center console apart and under a black vent tube there should be plugs like in the picture above, they are kinda stuffed in there so look good. good luck I could not believe my eyes also
Old Jan 23, 2008 | 04:17 PM
joedaddy1's Avatar
i think it's just a harness that's there, i don't think the seats don't have coils in them.if u goto everythingg35.com they sell seats with or without heating material
(I think you mentioned it somewhere)
DOMO
Old Jan 23, 2008 | 05:00 PM
bert039's Avatar
Damn, I think you're right.... that's too bad.
Old Jan 23, 2008 | 08:14 PM
MightyG35's Avatar
... But on another thread someone was saying that everything was there, just not the switch. TTRANK, what was the outcome of your old 03.5? Did they have it built in just not plugged?
Old Jan 23, 2008 | 08:33 PM
InvincibleG's Avatar
I plan on buying switches this week and investigating. I talked to Diesel and Ttrank but neither knew for sure. I have an 03.5 with power so I hope I can just put switches in and be all toasty. I will post results anyone else who tests please do the same!
Old Jan 23, 2008 | 10:04 PM
Rodrigo's Avatar
yes please post results
Old Jan 24, 2008 | 02:21 AM
DaveB's Avatar
You can buy the heating inserts from aftermarket leather cover companies for like $100 and do the wiring yourself if the harness is there. The lower seat cover comes off quite easily.
http://www.leatherseats.com/products2.asp?c=7&id=367
Old Jan 24, 2008 | 11:12 AM
MidnightG35X's Avatar
Originally Posted by ttrank
I use mine here in Phoenix this time of year. It's nice when I work late, it's dark, ~45 outside, remote start the car from my office and my seats are nice and warm when I get out there.
Ooo a brisk 45 It was -20 this morning in Iowa. Just giving you crap Tim, I'm actually gonna be in Phoenix early next week, so I'll be the guy running around in shorts if it is higher than 50 degrees out. Gotta love work sending you to Phoenix during Super Bowl week!
Heated seats do help quite a bit in this type of weather though
Old Jan 24, 2008 | 11:30 PM
MightyG35's Avatar
bump
Old Jan 28, 2008 | 02:16 PM
MightyG35's Avatar
any updates???
Old Feb 6, 2008 | 08:38 PM
DaveB's Avatar
I just confirmed that my 2003 G35 sedan (doggy door) does have the connectors as pictured. The FSM is not clear on what the heated element connector under the seat would look like. Now I just wish I had the switch to see what happens.
Old Feb 7, 2008 | 12:55 PM
Sorry fellas I have been sick and stuck at home all week and on Monday the G is going to the body shop So I will try and get switches this week and install when I get the car back
Old Feb 7, 2008 | 10:07 PM
04G35NYC's Avatar
nice info, on a side note anyone need the console with heated seats buttons? i have extra console because i switched from all black to silver since my DD is silver so i had to get the console silver as well.
Old Feb 8, 2008 | 12:23 AM
GHong's Avatar
There was a TSB on this if you search
I actually have the same issue...it barely feels like the seats are working sometimes...I checked the TSB section but couldn't find anything when i searched. Does anyone have the link to where this issue was addressed or know what I can do to fix it? Thanks!
Old Feb 8, 2008 | 04:36 PM
  #30
Sacch's Avatar
I have the same problem... this should be covered under warranty right guys?
