Windows & Remote
Old Mar 17, 2004 | 02:19 PM
GeezerB's Avatar
Windows & Remote
In the manual that came with the car, it points out that if you hold down the lock button for 3-5 seconds, the windows will roll up automatically. Mine don't. I tried 10 seconds, no go.
It also states the windows will roll down if the unlock button is held. Mine don't.
Am I missing something here? I have had my '04 auto w/premium for only 2 months. The weather has finally reached a temp that benefits an open window or two. I did try the method of inserting the key & turning it forward to close the windows. That did work, but no remote.
GB
2004 DG 5AT
Aero Sport Premium
Old Mar 17, 2004 | 04:15 PM
SoCalTed's Avatar
Re: Windows & Remote
hmmm I know the 02-03 only roll down. They do not roll-up. Don't know about the 04's...
-T
'03 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS or Vote at Online Showoff
Old Mar 17, 2004 | 06:59 PM
ctxca's Avatar
Mine doesn't roll up with the remote either. I read the manual and I don't recall seeing that it is supposed to. Only roll down. I have a 2004 w/ Premium. If you can tell me what page you saw it in the manual, I will check it out and see what I can find out.
Old Mar 17, 2004 | 10:42 PM
Specialist23's Avatar
ditto.
Old Mar 18, 2004 | 12:54 AM
ryoken's Avatar
You can roll them up with the key in the door, but not with the remote. Look in the Audio/Video forum, though.. a guy there is building a module to create that feature.
IIRC, the roll down feature works with all doors unlocked.. so in the default setting where the first click unlocks the driver's door and the second click unlocks them all, you have to hit unlock twice, and hold it down on the second click. If you have your settings adjusted to open all doors on the first click, then the window roll down should operate on the first click.
Old Mar 18, 2004 | 02:28 AM
G35XLOVER's Avatar
Thanks for the info i never new that.
now that works on all cars that have remote control or power window.
Old Mar 18, 2004 | 03:35 AM
ryoken's Avatar
One other thing I forgot to mention.
You have to have the Premium Package (with the auto up-down rear windows) for all four windows to go down with the remote or up/down with the key. If you do not have the premium package, the key/keyfob will only operate the front two windows.
Old Mar 18, 2004 | 04:51 AM
Msedanman's Avatar
O.F. Administrator
Mine only roll down when the unlock button is pressed for more than 3 seconds. My sedan was the same.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Mar 18, 2004 | 09:05 AM
g4ian's Avatar
I don't have the premium package and I thought for sure that my rear windows will go down with holding the key fob, but they go down sequentially, with the front windows first, then the back windows a half second later. My manual also states the same and I don't recall it specifying only with the premium package. Now I will have to check to make sure I am not losing my mind....
g4ian
Old Mar 18, 2004 | 12:40 PM
GeezerB's Avatar
OK, I did make a false assumption. Nowhere does it say that the windows raise with the remote. I must have confused it with the key in the door feature. I apologize.
I have to blame the error on the fact that I was so excited the night I brought my G home, I sat in the car, reading the whole manual in one pass. It took a long time. Many of the features I did not try out at that time (such as the windows) due to the weather & darkness. Now that the weather here has improved, I tried to access my memory & came up with my last post.
Sorry, I will be more careful with my questions.
I'm still having trouble resetting the ECU. Should I just disconnect the battery?
Thanks all for your replies.
2004 DG 5AT
Aero Sport Premium
Old Mar 19, 2004 | 03:06 PM
ctxca's Avatar
no worries Geezer, we don't have to be perfect, that's why we buy cars that bring us one step closer to perfection.
There is a post w/ all sorts of details about ECU re-setting in technical modifications I believe - it should give you the answers you're looking for.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
