Squeaky Suspension / Chassis
New guy to the Forum here. I've got an all stock 05 5at Base model
It seems like all the suspension bushings in the front end are dry. If I go over medium sized bumps or pull into my driveway slowly, I can hear what sounds like the control arm bushings squeaking. I've looked all around the car and couldn't fine ANY zert fittings to grease the suspension.
Does or did anyone else have this problem? If so, how did you go about fixing it? Common Problem?
https://g35driver.com/forums/g35-sedan-v35-2003-06/196616-look-here-before-starting-new-thread-2003-2006-sedan-faq-s.html
Here's an excerpt:
Q - Why does the front end of my car make creeking noises at low speeds going over driveways/speed bumps etc?
Check (or have a dealer /shop check) the compression rods which are known to go bad and can be replaced under warranty from dealer.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
