is there a dealer software upgrade for auto transmissions?
Old Mar 17, 2008 | 01:38 AM
infinitialex's Avatar
I have 03 G35 auto
i heard there might be upgraded software for auto's available from dealers
anyone heard of this?
I cant find any info on the forums
Old Mar 17, 2008 | 02:01 AM
MM_G3520's Avatar
I remember hearing something about this. I would also be interested.
BTW, Motordyne > Skunk
Old Mar 17, 2008 | 03:57 AM
Kazaam's Avatar
02 G35 auto???
Old Mar 17, 2008 | 04:08 AM
03,,sorry
Old Mar 17, 2008 | 08:49 AM
NorthSideRacing's Avatar
Valve body upgrade
Old Mar 17, 2008 | 11:03 AM
DaveB's Avatar
Yes, but good luck getting the dealer to do it because they'll probably look at you like a deer in headlights. If they are willing to do it, expect to pay $80-120 to have them do the flash. These are the ECU/TCU update programs are:
Part # 23710-AM604
Part # 31036-AL004 (newest verison I believe)
Old Mar 17, 2008 | 12:00 PM
sliderg35's Avatar
What issues does the update address? (Will it rev-match, show the actual gear in the display on auto downshift...)
Old Mar 17, 2008 | 12:17 PM
davidm99's Avatar
20 Year Member
Sedan
I looked into this also and I agree with DaveB, good luck. When I asked about this the replies that I got were deer in the headlights to down right nasty. One option would be to go to: http://www.nissan-techinfo.com/infin...m.asp?mscssid=
and to download the TCM/ECU update, you can get temporary access to the site to download the software. But then the only problem is finding some with with a Consult II or III and know how to upload the new program.
From what I have read else where Part # 23710-AM604 is the newest version for our cars.
Old Mar 17, 2008 | 02:05 PM
Aha ,, I talked to my local dealer and they said $35 is all they will charge me if I have the update #s. Now are the codes year specific or what? I have an 03 will this update work?
Old Mar 17, 2008 | 02:35 PM
68_GT's Avatar
this is a dealer reflash ? crazy... what are the benefits ?
Old Mar 17, 2008 | 03:13 PM
GixxerSteve's Avatar
Per an old post by DaveO that I found:
Originally Posted by DaveO
The latest ECU/TCU program is Part Number 23710-AM604. This program significantly improved the normal auto mode driveability and reduced the A/T's downshift time.
I had previously upgraded the original 31036-AL000 program to 31036-AL004. This had helped a little. Gord's 10-wire GroundingGgear kit helped more. The Stillen valve body increased the speed and firmness of the shifts (especially in MM), but not the delayed kickdown time.
Those in Southern California can contact Mike Longridge at Riverside Infiniti or PM Chad@InfinitiSpecialists (a sponsor here)... they can hook you up. The reprograming runs about $100.00.
DaveO
Old Mar 17, 2008 | 04:51 PM
DieselX's Avatar
Will doing this upgrade effect my TechnoSquare reflash in any way?
Old Mar 17, 2008 | 06:34 PM
UPDATE:
Ok guys just went to my local Nissan dealer, they had no problem with doing the reflash. They found all the codes in their system , turns out 31036-AL004 is a code for Transmission reflash and 23710-AM604 is actually for engine ECU reflash. I did both, took around 45 minutes to do as program loads pretty slow into the vehicle. Cost me $54
Now it might be a little too early to determine if shifting or anything else has changed on my car, but initial impressions or "Placebo Effect" do suggest that shifting has less lag, shifts happens more when i want them shift and not the other way around how it was before. I will post more results after a few days of driving...
Old Mar 17, 2008 | 06:48 PM
I forgot to mention , guy that was doing the reflash also checked my o2 sensors and AF ratios fro no charge. AF ratios from what he told me look very good at load and a little rich at idle. Although I'm not exactly convinced that his method "one foot on brake and other on gas" is sufficient enough to determine full load ratios...
Old Mar 17, 2008 | 10:31 PM
RADIOGUY21's Avatar
is this is for the 03/04s only?
