compression rod
Old Mar 17, 2008 | 01:33 PM
shorswill's Avatar
compression rod
Can anyone tell where I can order a right front compression rod for an 03 sedan? Dealer wants $330 + installation = $500.
Old Mar 17, 2008 | 01:35 PM
O HELLA OEM's Avatar
tony@riverside
Old Mar 17, 2008 | 01:38 PM
Boston's Avatar
^ +1 on Tony. He got me my rods 3 months ago.
Old Mar 17, 2008 | 01:51 PM
NonAme's Avatar
doesn't warranty cover it? mine did. went in for oil change, dealer did their complimentary multicheck points and found both my front rods were shattered to helll. replaced it right then and there.
Old Mar 17, 2008 | 02:34 PM
RADIOGUY21's Avatar
^ hes most likely out of his 4 year warranty.
Old Mar 17, 2008 | 03:35 PM
naughty240's Avatar
just had mine done under warranry. List was 180.00 each
Old Mar 17, 2008 | 07:07 PM
G35Papa's Avatar
+2 for Tony@riversideinfiniti
I just got mine from him last week. Installing myself on Wed.
Old Mar 17, 2008 | 07:45 PM
OCG35's Avatar
Since its 03, might be out of warranty... if not, insists that they cover it - many of us have had it done under warranty
Old Mar 17, 2008 | 08:26 PM
jibnasty's Avatar
Anyone know of a DIY for this? What will happen if it is driven on and the noise is ignored? I think mine is making the noise...
Old Mar 17, 2008 | 11:31 PM
G35Papa's Avatar
See first post in this thread. I am going to do mine this week. If I feel up to it, ill take some pics. Sorry, sometimes I'm lazy
https://g35driver.com/forums/showthr...mpression+rods
Old Mar 18, 2008 | 04:50 AM
erdog's Avatar
It is pretty easy. You may have to use the jack to lift up the wheel a bit after you put the car on jack stands in order to remove and put on the new rod. Other than that...it is a simple swap. Don't forget to swap out some of the rubber pieces if you didn't order new ones.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
yosip1115
16
Sep 28, 2015 04:14 PM
