Battery died over the weekend
Old Jun 8, 2008 | 09:44 AM
Dan in St Louis's Avatar
Originally Posted by jimrockford
.02-.06 amps which is 2-6 milliamps
That would be 20 - 60 milliamps.
Old Jun 8, 2008 | 11:36 AM
picklejuice's Avatar
or 2-6 centiamps
Old Jun 8, 2008 | 05:26 PM
jimrockford's Avatar
Damn metric system. You're correct. I should have said .002 to .006 amps which is 2-6 milliamps.
I'm really batting a thousand...or is that a hundred?
Old Jun 10, 2008 | 07:59 PM
5150DS's Avatar
Technically, yes, but there are differences such as; an alternator puts out A/C current and a generator puts out D/C current.
Old Jun 11, 2008 | 12:34 PM
really? generators are dc? that's funny because i'm an electrical technician at a power plant and i work with generators that produce three phase ac. ni hao ben a.
Old Jun 11, 2008 | 01:32 PM
5150DS's Avatar
Yes, it is a generator because it generates electricity, but if it puts out A/C it is an alternator. From Miriam Webster:
Main Entry: al·ter·na·tor
Pronunciation: \ˈȯl-tər-ˌnā-tər also ˈal-\
Function: noun
Date: 1883
: an electric generator for producing alternating current
Old Jun 11, 2008 | 01:56 PM
G SEDAN's Avatar
ni hao ben a.
he said "you are so stupid"....
FOB!
Old Jun 11, 2008 | 02:53 PM
5150DS's Avatar
Read my above post. Maybe he needs to put down the Chinese dictionary and pick up an English one.
Old Jun 11, 2008 | 02:56 PM
G SEDAN's Avatar
I personally agree with you, I just thought it was funny that he'd call you stupid in a language you didn't know.
LMAO at the dictionary comment
Old Jun 11, 2008 | 03:00 PM
5150DS's Avatar
My favorite part is, he has a total of five posts and he is already showing what a total A$$hole he is.
Old Jun 11, 2008 | 03:23 PM
fais's Avatar
Sorry to go off topic but I wouldn't rely on a dictionary to tell me what a generator is...I'm in 4th year Electrical Engineering and picklejuice is right, generator does not necessarily output DC, it produces AC and with a commutator can output DC
Old Jun 16, 2008 | 01:25 AM
cdzhaha's Avatar
Originally Posted by RCMCFE
Same problem here...It's your radio.
What do you mean, it's the radio? This was happening before I got my head unit replaced and got worse after. But didn't happen the first five years I had the car.
I'm not following what you're saying -- turn the radio off? Take the radio out? Fix something in how it's installed?
Old Jul 8, 2008 | 12:15 AM
prathap's Avatar
PLease help with the battery issue.
Last time my car was in service, I was told my battery was going bad and that I needed a new battery. I went to Costco this evening and bought a battery.
These are the steps I followed in putting the battery in.
I removed negative terminal first and then the positive terminal. Took the old battery out and put the new one in. It was a tight fit, however managed to get it in there. I connected the positive terminal first and then the negative.
These are all steps from infiniti manual. I guess these were correct.
Once I was done with it and I started the car and drove around the block. I noticed some of my settings were missing, such as radio stations and the like. I reprogrammed them.
Once I was in the garage I turned the engine off and started again a couple of minuted later. The car starts completely and shuts down. After a few attempts, once when I was starting I gave it a little bit of gas and the it stayed on.
This is how it works for now. I'm afraid I cant go to work tomorrow relying on this.
What could be wrong for this behavior? Is there something I could have done wrong?
Please help,
any help is appreciated.
Thanks,
PK
Old Aug 20, 2008 | 04:33 AM
G35Halo's Avatar
PK
Which model? I'm planning on either going to costco or pepboys for a new batt tomorrow. thx.
Old Sep 13, 2008 | 11:55 AM
  #30
barrios35's Avatar
I have the same problem. Bought a new battery from Nissan and about a week later it is low. I pulled all the fuses draw is unchanged at .72 ma.. And ideas? One question when I was testing nothing was functioning? Is it supposed to? Like the doors lights and what not? If it is the diode in the alternator do I have to pull it out to get it tested?
Was there ever a resolution to orginal posters battery draw?
