Check Engine Light On!!!
Old Apr 4, 2008 | 09:29 PM
TOPNOTCHSEDAN's Avatar
Can Any One Help Me With This??? I Just Installed My Stillen Grounding Wires And My Check Engine Light Came On Can U Guys Tell Me Y Or What I Could Do To Get Rid Of It Besides Going To The Dealer... Thnx.
Old Apr 4, 2008 | 09:31 PM
03Sg35's Avatar
Read the FAQ for once, unplug your battery for 30min or take it to Autozone and they can reset it also for free.
Old Apr 5, 2008 | 12:35 AM
lexusk8's Avatar
My instinct tells me that you installed some part of the grounding wires wrong which led to the check engine light but as the other guy mentioned, go to Autozone and get the CEL diagnosed. I also have the Stillen grounding kit, and no issues came up after I installed it.
Old Apr 5, 2008 | 01:14 AM
sliderg35's Avatar
It's pretty hard to screw anything up by installing a grounding kit. Chances are that you disconnected something by mistake. Open your hood and check that all plugs are still connected - vacuum hoses as well.
Old Apr 5, 2008 | 05:26 PM
ttrank's Avatar
Grocery getter
Take it to a local parts store and have them read the code to see what caused it.
Old Apr 5, 2008 | 10:25 PM
Thnx Alot Guys For All The Info... I Did What O3sg35 Told Me To Do And It Worked.... I Unpluged The Battery For 30 Min And That Did The Work... Thnx ... Check Engine Light Is Off...
Old Apr 6, 2008 | 02:44 PM
ttrank's Avatar
Grocery getter
If the problem is still there it may come back in the next few days. If it does, go have the code checked out. It's free at any parts store. I have an OBDII reader in my car just in case I ever get a code.
Old Apr 6, 2008 | 07:27 PM
Oh right on thnx...
Old Apr 15, 2008 | 08:40 PM
farsey's Avatar
hi after installing the intake couple days later my check engine light went on and i went to get the code its p1121 they told me it was sensor for the intake can any one tell me how would i able to fix it thank you
Old Apr 15, 2008 | 08:41 PM
farsey's Avatar
Old Nov 6, 2008 | 06:56 PM
txc_iggy's Avatar
I get the P1121 Electronic Throttle Control error code on my G a week after I changed the headlamp housing. Is it possible that during the installation, something got jacked?
As of now I got the code reset, hoping never to see it again.
Muski_G
Dec 1, 2023 11:11 AM
Jay 21
Aug 5, 2015 04:53 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
