exclamation point
Old Apr 27, 2008 | 03:51 AM
silver04g's Avatar
exclamation point
Hello, I just bought a 2004 G and I have a question. My car recently showeda exclamation point on the dash. I thought it may be a check engline light so, I took it to auto zone and let them run a diagnostic check and it came up with no codes. It comes on and off often and im not sure what it means. Anyone know what this means? Thanks.
Old Apr 27, 2008 | 03:57 AM
psedog's Avatar
Back in SD**
TPMS, Tire pressure sensor light.
It just means your sensors aren't talking to your car, or you don't have sensors, or they need to be re-programmed.
Old Apr 27, 2008 | 04:01 AM
silver04g's Avatar
Ok thanks... How do I correct this problem?
Old Apr 27, 2008 | 04:29 AM
psedog's Avatar
Back in SD**
First check your wheel to see if you have these types of stems
If you don't then you don't have TPMS in your wheels. If you do, then check your tire pressure. Make sure you have at least 30psi in all of your wheels. If you do, then you have a problem. Many situations can cause the system to act up and only the dealer can really find out why (as far as I know). Honestly, the hassle isn't worth it. I have always checked my own tire pressure every other fill up.
Marlin84
Apr 1, 2020 12:52 PM
g.spot
May 9, 2016 10:54 PM
vamarris
Sep 26, 2015 12:56 PM
