Seat memory issue when set on "auto"?
Alright, so if I'm reading the manual correctly, you can set a specific seat position and designate it as 1 or 2 on the side, set it on "auto", and when you unlock the car the seat is supposed to automatically scoot back a few inches to help you get in a little easier, then when you close the door (or start the car?) it scoots back up to whatever position you have stored in the memory. Is this right? Because my seat never moves back when I unlock the door. My 04 sedan is still under warranty and I'm taking it in soon for another issue, so if I can knock this out at the same time that would be great. I just some clarification on what the "auto" feature on the seat is supposed to do. Thanks.
im pretty sure i programmed it right, the 1 position is just where i like it. ive check to make sure i have it set on auto, and i do, ive just never witnessed it slide back when i unlock or open the door, and it never slides forward once i close the door. you say you had yours disabled, how was that done? i might check to see if mine is disabled.
the on/cancel is referring to the entry/exit assist. on my 04, when you have that funcion on, it will scoot back when you turn off your engine and pull your key out. when you put your key back in, it scoots inwards again. I know this function works differently on an intelligent key, but essentially does the same thing.
I also experienced that you will not get any entry/exit exist if your seat is scoot back very far already. so essentially, if your comfortable setting is set back really far (because you're a tall guy) then the seat will decide you don't need the entry/exit assist. if you really want to test out if that function works, set another seat position a lot closer to the steering wheel and you should experience the entry/exit function.
oh and one more off topic question for you G Sedan. i see you have the aero kit and splash guards. i have the aero kit as well and would like to add the splash guards but wasnt sure they still fit with the aero kit. will the one for the rear bumper fit, or will only the ones along the side skirt fit?
I just wanted to do something different with the sideskirts
Micale757
Lighting
Apr 8, 2020 10:46 AM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
slider_ua
Jul 29, 2015 04:17 PM
