UNEVEN DROP??? (left to right)
Old May 13, 2008 | 11:21 PM
G35xChicago's Avatar
hey guys, maybe im completely stupid...but i just lowered my 05X all 4 sides 10 ago using coupe springs. Had an experienced mechanic do it. Not sure if i noticed this before but for some reason now the back left sits a finger length lower than the back right. After measuring this quickly w tape measure, it seem like just about a 1/4" difference. I have a pretty full tank of gas, but its actually on the side that rides higher so that cant be it...i beleive i am on even ground when i checked...nothing heavy in the trunk.....I also havent gotten around to getting an alignment (been waiting until springs settled some)....
assuming (hoping) the springs were a matching pair (picked them up locally) is this an installation or alignment issue?
Old May 13, 2008 | 11:25 PM
G35Papa's Avatar
Most all cars lean like that. Especially with lowering springs, it makes it more noticeable. Height adjustment and flexibility of coilovers allow you to fix that "problem"
Old May 13, 2008 | 11:30 PM
Aka-Willi's Avatar
I had the same problem. I installed a set of Tein Basics and despite the length of the rear collars for left and right were set exactly the same, there was approximately a 1/2" heighth difference, the right (passenger side) being higher. Fortunately I have coilovers to offset this height difference.
Old May 13, 2008 | 11:39 PM
re
yea unforunately there is not way i can spend 1800 on X coilovers, which no one really even produces. visually it doesnt bother me much, both sides in the back regardless look nice and low...i just dont want it to mess anything up suspension/performance wise...(besides my camber issues which hopefully ill get adjusted)
and yes you are correct, the fact the rears are both close to the wheelwell now makes it very noticable, easy to pick out...
Old May 13, 2008 | 11:43 PM
Nikos35's Avatar
put a fat chick in the passenger seat! j/k man.... my silverado was like that when I dropped it so I just rolled it as is and hoped it would settle. now my daughter drives it so I don't even care lol....
G35Papa's Avatar
^A 1/2" seems like alot. I wonder if the springs were installed backwards.
Old May 13, 2008 | 11:51 PM
Aka-Willi's Avatar
I thought that also, but checked and they are right side up.
Old May 13, 2008 | 11:52 PM
im sure mine were done right, theoretically, the guy knows what hes doing, by backwards, do u mean upside down or something
Old May 13, 2008 | 11:56 PM
Nikos35's Avatar
front-back
Old May 14, 2008 | 12:00 AM
(>")> G35's Avatar
There's other with the same problem "issue":
https://g35driver.com/forums/g35-sedan-v35-2003-06/146099-rear-car-uneven.html
Did you get an alignment done? Since posting that I had an alignment done. Turns out my camber specs were -1.3 left and -.5 right. The left side was flush again after the alignment, but I haven't bothered comparing the height of the left and right yet.
Old May 14, 2008 | 12:15 AM
https://g35driver.com/forums/showthread.php?t=146099
thanks, definately sounds like the same problem im having, my camber is sorta off, but more off front to rear, not side to side as much. either way, ill get everything aligned, then well see..
Old May 14, 2008 | 11:08 AM
G35Papa's Avatar
When I said backwards..I meant upside down...sorry. The "flat" side of the spring should be facing upwards.
Since you are dropped on coupe springs (about 1/2" drop) you shouldn't have to get it alligned. Thats not enough drop to throw anything off.
Old May 14, 2008 | 10:34 PM
re
well i have a an X so it drops everything .5 more, so its about an inch, and my camber is -2....
Kelvin Style006
May 23, 2016 03:47 AM
twentyeggs
Sep 11, 2015 03:58 PM
vstring
Sep 11, 2015 02:50 PM
NJ6MT
Sep 10, 2015 08:40 AM
