Does 04 6MT Sedan have LSD?
Old Apr 19, 2004 | 02:11 PM
BrianV's Avatar
Per this thread:
https://g35driver.com/forums/showthr...age=&view=&sb=
I was under the assumption it did not, just VDC which to me is borderline worthless.
Can someone please verify the accuracy?
Old Apr 19, 2004 | 02:18 PM
dklau33's Avatar
Re: Does 04 6MT Sedan have LSD?
Yes, all 04 6MT Sedans come with a Viscous type LSD from the factory. If you wanted to you could swap that out with a number of aftermarket Clutch type LSD's like Nismo, Kaaz, Cusco to name a few. Currently, several members are trying to get Quaife to make a Torsen type LSD as well for our application.
04' G35S 6MT Ivory Pearl, Willow, Premium
Old Apr 19, 2004 | 02:43 PM
BrianV's Avatar
Wow, this is the best news of the year, seriously, I thought all we had was that lame eletronic VDC; to hear we have a mechanical LSD is great.
I always wondered cause it seems like when I dump my clutch from 2000-2500 I get a little of wheel chirp but it hooks fast and ferociously.
Finally, when VDC is set to 'Off' is it really completely off? I know on the Benz's it never really shuts off, but on the G does it. When I shut the VDC off I should have no traction/stability controlling devices except the viscous mechanical LSD?
Old Apr 19, 2004 | 02:47 PM
ikSardarG's Avatar
From what I know, when the VDC is off, its never really off unless you pull the fuse. Pulling the fues for the VDC, means you also pull the fuse for the brake lights and the ABS system too...
We need a workaround for this though... I would happily purchase that feature... I would love to know how much drift I can get with my G...
Navi-Conversion Kits at Discounted Pricing
*Authorized AV Electronic Dealer*
2003.5 Desert Platinum Sedan
Premium, Navi, xBox
Old Apr 19, 2004 | 02:49 PM
BrianV's Avatar
I notice when it's off I can get some pretty decent sideways action. I'm no drift-racer so I don't try and go all out, but a little swing around a turn is plenty for me, and with VDC off I get that with no problem.
Old Apr 19, 2004 | 05:56 PM
dklau33's Avatar
"I always wondered cause it seems like when I dump my clutch from 2000-2500 I get a little of wheel chirp but it hooks fast and ferociously. "
Yup, a viscous type lsd starts limiting slip after traction is lost. A more performance oriented clutch type or torsen type lsd will start transferring power to the other wheel with more traction BEFORE slippage occurs.
Old Apr 19, 2004 | 07:12 PM
6speedG35sedan's Avatar
Where can I get the LSD that is currently being produced by NISMO or Cusco, and what is the cost for parts and labor?
Thanks
Base 6MT Silver sedan
Stillen Exhaust
Stillen CAI
Eibach Pro Kit
Eibach Sway Bars
Old Apr 20, 2004 | 12:20 AM
dklau33's Avatar
One place that sells the Nismo...
http://www.performancenissanparts.co...products_id=59
Another that sells the Nismo, Cusco, and Kaaz...
http://www.gruppe-s.com/350z/ztrn.htm
All these LSD's above will generally cost around 900-1000 and labor I'm guessing will probably be another 200-300 as they have to drop your stock diff and put in the new one. People with auto's would have to buy extra stock parts that are allready on the 6MT's in order to fit up the new diff. Be aware that clutch type diffs probably perform the best but will make the most noise during operation.
Old Apr 28, 2004 | 01:00 AM
geeitup's Avatar
Sounds like you know what you're talking about - but do you have any documentation for the '04 LSD? I thought I read it was a new feature available in '04.
Old Apr 29, 2004 | 11:36 AM
doogie's Avatar
<hr></blockquote>
Are you sure that's right? I know they come with an LSD but I thought it was just an electronic lock diff, not a fancy viscous LSD
Jase aka Doogie
04 G35S
Old Apr 29, 2004 | 12:33 PM
BrianV's Avatar
I'm still trying to verify this.
Old Apr 29, 2004 | 02:07 PM
THX723's Avatar
G Kreuzer
yes ... it does have mechanical LSD in addition to the brake-LSD. That was the big thing for '04 *6mt* sedan.
Clint (THX723)
Old May 6, 2004 | 10:14 AM
SixgearSedan's Avatar
I drive with mine off all the time. Except when roads are wet. All I know is that if I raise the RPM to 4000 and pop the clutch is leaves 2 tread marks behind all the way through first gear. Occasionally I get that annoying wheel bounce.
Old May 6, 2004 | 11:16 AM
ryoken's Avatar
I doubt you're driving with it off.
If you have the VLSD, it's mechanical, and the only way to drive with it off would be to replace your differential with a regular open diff.
If not, the Brake LSD portion of the VDC system does not turn off when you turn off VDC. This is the one piece of the system that remains active. To shut it down completely, you'd have to pull your ABS fuse, which I would not recommend.
Old May 6, 2004 | 04:44 PM
dklau33's Avatar
In reply to:
Yes, I am 100% sure that is right. Again all 04 6MT sedans have a rear Viscous Limited Slip Differential. I see you have an auto so you don't have one. But you could have one (or an aftermarket one) swapped in if you wanted to with the purchase of extra stock parts as well such as the ring and pinion gear. VLSD's aren't all that fancy in comparison. Viscous goo is used as a medium to limit slip between the two tires. Much better than an open diff for sure. More fancier versions of LSD's are clutch types and torsen types. Clutch types uses a series of plates and clutches while torsen types uses gears. This technology is more fancy and yet more expensive. Hopefully Quaife comes out with a LSD soon.
tiguy99
Mar 1, 2016 11:42 AM
derres
Aug 28, 2015 03:27 PM
TheKnite
Aug 14, 2015 07:59 PM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
