Anyone Installed USA Spec IPOD Interface?
Old Jun 5, 2008 | 03:35 PM
ITSAGTHING's Avatar
Has anyone out there installed the USA Spec Ipod Interface? Apparently it would work with my 04' but i kinda wanna make sure. I would buy the nissan one but i need a Aux in. Let me know what yall think.
Old Jun 5, 2008 | 04:38 PM
chewy's Avatar
it is great, I have it on my 03 coupe.
Old Jun 5, 2008 | 04:52 PM
ITSAGTHING's Avatar
Any advice on the install? Easy/Hard? Anything will help. Mine is on its way.
Old Jun 5, 2008 | 05:44 PM
g35freak86's Avatar
I never did any type of radio/stero install myself ever and I tackled this on my 03 sedan and it was straight forward and very very simple. it is an AWESOME unit. Couldn't be happier. only hard part is understanding how to take the whole HU out and everything. Involved process but it's easy once you do it a couple times
Old Jun 5, 2008 | 05:48 PM
ITSAGTHING's Avatar
Can you describe at all? Do you remove the ring around the gear shifter, clock area, etc? do those pieces just pop off?
Old Jun 5, 2008 | 05:49 PM
g35freak86's Avatar
There is a DIY on here.. just got to look for it.... I'll post back with the thread in a sec
Old Jun 5, 2008 | 05:53 PM
g35freak86's Avatar
https://g35driver.com/forums/audio-video-electronics-diy/90507-diy-06-hu-removall.html This is for an 06 though and 6MT. But it's pretty much the same concept. When they say put into 4th gear to remove the center console pannel... for 5AT put it in Neutral. It's pretty much the same.. only a couple different screws here and there. But it will give you a good idea. But fpr the 03's and 04's you need to take the side pannels on the side of the HU off too. To do that you need to take the glovebox off and underneath the drivers side... pretty much taking all the pannels off on the front of the dashboard to access all the screws needed to get to it
Old Jun 5, 2008 | 05:57 PM
ITSAGTHING's Avatar
https://g35driver.com/forums/showthread.php?t=90507 This is for an 06 though and 6MT. But it's pretty much the same concept. When they say put into 4th gear to remove the center console pannel... for 5AT put it in Neutral. It's pretty much the same.. only a couple different screws here and there. But it will give you a good idea. But fpr the 03's and 04's you need to take the side pannels on the side of the HU off too. To do that you need to take the glovebox off and underneath the drivers side... pretty much taking all the pannels off on the front of the dashboard to access all the screws needed to get to it
You are the man. I just hope it works in my car. someone said that it doesnt in the 04's because it doesnt have the CD/Changer button. We will find out.
Old Jun 5, 2008 | 06:06 PM
g35freak86's Avatar
it works. you just got to press DISC twice I beliece until it says CD CHG 1. make sure there is a cd in slot 6. I got an 03. It works trust me haha. You don't need a SAT or AUX button. Just press DISC twice and you're good to go
Old Jun 5, 2008 | 06:10 PM
ITSAGTHING's Avatar
Found it. Check it out.
Thanks
http://www.g35ipod.com/installHW.php?skin=1
Old Jun 5, 2008 | 06:27 PM
g35freak86's Avatar
there it is. i used that one. goodluck man! you'll love it!
Old Jul 2, 2009 | 03:16 PM
villybhakta's Avatar
What if I have an 03 sedan with a head unit that has a SAT button. I have already tried the PAI-NIS2 but that didn't work. My SAT button is broken or something. So now I am looking at the USA spec IPOD adapter. Will it work for me?
Old Jul 2, 2009 | 03:33 PM
g35freak86's Avatar
yes. I do not have the SAT button. Just press the DISC button twice until it says CD change (or something like that) and the ipod will play
Old Jul 2, 2009 | 04:21 PM
no, I DO have a sat button. Does that make it incompatible?
Old Jul 2, 2009 | 04:26 PM
g35freak86's Avatar
works with either button
