Taillight LED's Not Coming On
Old Jun 12, 2008 | 02:59 PM
providox's Avatar
Hi i have a 2003 G35 and i noticed yesterday that on the left taillight the LED's on the 3rd row aren't coming on. The first and second row light up fine.
Has this happened to anyone before and is there anything i can do to fix this or do i have to buy a whole new taillight?
Old Jun 16, 2008 | 11:23 AM
providox's Avatar
bump
Old Jun 16, 2008 | 12:10 PM
Mmagic76's Avatar
Pretty sure you'll need a new headlamp assembly. Shouldn't cost too much to replace, there are a bunch of ppl who have upgraded to 05-06 tails who will probably sell their used ones for cheap. Also check Ebay.
Old Jun 16, 2008 | 12:18 PM
G35Papa's Avatar
I have a set I'd be willing to sell...as a set though, not individually.
Old Jun 16, 2008 | 06:53 PM
ttrank's Avatar
Grocery getter
I just saw someone else have this question in another thread, was that you?
Either way you will need to replace your light. Unlike the headlights, the taillights are a huge pain to open up. Even if you got them open without damage there is no saying if you would be able to fix the problem LED's or replace the whole board.
Since you have the 03/04 lights which are not in demand like the 05/06 you would be better off looking on ebay or something for one.
Old Jun 17, 2008 | 12:26 PM
racefan318's Avatar
after you take the non-working taillight out, take it apart to get the LED's and you can fab some GTR-style light bars for the front... or send it to me and i'll make them for my wife's 03...
they may glow red though... don't know if the LED is red behind the lens or not.... I would think it was just a white led
Old Jun 17, 2008 | 03:09 PM
providox's Avatar
ok new information this morning when i checked the tail lights again all the led's were on.... however when i reached back home and checked them again the third row was back off.
Anyone know what can be causing this? And does this mean i don't need to buy a new tail light?
Old Jun 17, 2008 | 03:53 PM
Mmagic76's Avatar
Loose connection probably, like ttrank said, it's hard to take apart unless u want to try it out.
Old Jun 18, 2008 | 11:20 AM
MidnightG35X's Avatar
They are definitely not white LED's behind the lens. They are red LED's. White LED's are about 3x more expensive compared to red/orange LED's. It would make no sense to use a white LED behind a red lens when you can just use red LED's for much cheaper.
If you want the exact same type of LED's as inside the taillights, go check out Philips Lumileds superflux LED's, or the Liteon LTL91XXXXXX superflux LED's.
Old Jun 18, 2008 | 12:57 PM
racefan318's Avatar
You might be correct, I just had to go verify for myself WHY...
http://www.superbrightleds.com/carbulb-notes.htm
For best results the LED color should be the same as the lens color. As an example: a red lens will filter out all but the red portion of the light so if the light is all red, none or very little light will be blocked by the lens. The light from a White LED contains very little light in the red portion of the visible spectrum so most of the light would be filtered out by a red lens
Old Jun 18, 2008 | 01:22 PM
RST531's Avatar
Factory LED's in the Taillight are White.
proven from a member here rugratcoupe, who disassembled them.
^^ not correct, LEDS are RED
Old Jun 19, 2008 | 11:03 AM
I have taken them apart many times myself... check the sequential mods in my signature. The lens/package on the LED is clear, but that does not mean the LED illuminates white.
Video of lights with no diffuser or lens
This is very true. LED's are monochromatic (outputs a narrow wavelength of light) as opposed to an incandescent which spews light all across the spectrum. You can use a color lens behind an incandescent and still get something. With an LED, you will get much less output behind a different colored lens.
Old Jun 19, 2008 | 01:28 PM
RST531's Avatar
my ref is from another member who does geat one-off mods, so he said it was white, i personally did not. also he was ref. to coupe taillights. actually i do have an open set of coupe taillights, ill try to plug them in this weekend to verify the color with pixs.
Old Jun 19, 2008 | 01:50 PM
I have done coupe tail lights also. They light up red. I'd post the pic, but photobucket seems down (as can be seen if you look at the coupe sequential thread in my sig). I do not want to sound condescending, I just want the correct information to be out there.
Old Jun 19, 2008 | 11:07 PM
RST531's Avatar
^^ agreed. but i comfirmed that led are red. i had a set apart for 2 months now and never lit them, until today. pixs attached.
Attached Thumbnails Taillight LED's Not Coming On-100_2347.jpg   Taillight LED's Not Coming On-100_2344.jpg
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
mtlruss
Dec 20, 2015 01:51 PM
linedr89
Aug 17, 2015 05:11 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
