Dash electronics problem
Old Jul 7, 2008 | 09:41 PM
blueharriss's Avatar
Hey guys, I have an 03 Sedan which is having an electrical problem. All of the dash lights work but there is no control over the radio, a/c, and all other center dash controls. It will periodically come back and give me control but most of the time none of the buttons work. The steering wheel controls for the stereo do work full time. Please help, its hotter than heck here and I need to control the AC! Thanks for any input.
Blue
Old Jul 8, 2008 | 12:05 PM
SoCalTed's Avatar
Intermittent use sound like a bad wire or crack in the board somewhere.
That's an integrated board, so not sure there is an easy fix for you. Sounds like you need a trip to the dealership.
Old Jul 8, 2008 | 01:00 PM
phast240's Avatar
My G did this the other day. I did a search on here and found that others have had similar problems. One thing I saw to try was to hit the "compass" button, and it will kick the dash lights back on. It worked for me, and I haven't had that problem since. If it does work, you may just want to put the A/C on "auto" and set the thermostat to whatever is comfortable (like 70 degrees). The a/c will still work if it goes back out, as long as it's on auto.
I think SoCalTed is right though, the board will have to be replaced. From what I've read, that seems to be the fix. May want to check junkyards or see if there's a way to separate the radio and a/c controls.
Old Jul 8, 2008 | 02:10 PM
nismo714's Avatar
if i had a penny for everytime i heard this issue
here's a thread i posted when i had this problem, should help you guys out. VERY common on our 03's
https://g35driver.com/forums/audio-video-electronics/210888-electronical-problem.html
when everythings said and done, you have 3 options 1) aftermarket HU (thats what i did loving it!!!) 2) visit this website, they refurb these www.shortcircuitrepair.com 3) take it to the stealership and get raped
Old Jul 8, 2008 | 06:06 PM
03Sg35's Avatar
option 4 buy used OEM unit and change it out. 200-300 bux
Old Jul 8, 2008 | 07:31 PM
Thanks to all!
Thanks for all the tips and the link to the thread, I did search but didn't find anything. I'm going to call the stealership tomorrow and see what they say. Then, I'll search junkyards and aftermarket.
Plur
Interior
May 22, 2019 04:35 PM
WillisFL
Dec 29, 2016 08:56 AM
wonderizm
Sep 24, 2015 03:09 AM
