Removal of passenger side front door panel
Old Apr 28, 2004 | 09:14 AM
WinterPeg's Avatar
Good Morning everyone;
I am new to this forum and have been searching for information on how to remove the inside front passenger door panel on my sedan. I have the "clicking" sound that has been reported. I had it on the driver's side and the dealer fixed it under the "adjustment" period but I purchased my sedan in April of 2002, so they said they would charge me to do the passenger side. I am pretty mechanical so I feel comfortable doing this. Your help is much appreciated.
WinterPeg
2003 Premium Sedan DP Auto
Old Apr 28, 2004 | 09:29 AM
SixFive's Avatar
Re: Removal of passenger side front door panel
Its still under warranty right? They shouldn't charge you for anything!
2003.5 DP 5AT Sedan (E-thing but Nav)
14.2 @ 97.18
Injen CAI
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Polk ex-3500 Tweeter Upgrade/Shock Sensor/H-Liner Under Hood
Old Apr 28, 2004 | 10:06 AM
cato's Avatar
SouthernComfort Moderator
There is no reason they should charge you for it, unless you
have over 60K miles! I have 39K miles and Infiniti still looks at
my car for free under warranty. Taking off the panel is easy.
Do a search and you should find pics and a write up on how
to do it.
2003 TwBlue 5AT Sedan, sunroof,
Graphite Leather, splashguards, HKS exhaust,
14 wire Grounding kit, 350Z duct, Stillen CAI
Underbody rear diffusers, Drilled alum pedals
Old Apr 28, 2004 | 01:23 PM
WinterPeg's Avatar
Hi Guys;
just got off the phone with the Service Manager and Infiniti Canada only covers these "adjustments" for the first 12 months. Don't have no other option as they are the only Infiniti dealer here. I did a search and found some diagrams on the coupe but none on the sedan. The coupe diagrams hopefully will be sufficient. If anyone has a shop manual for the sedans, a posting of the pages would be much appreciated.
Thanks.
WinterPeg
Old Apr 28, 2004 | 01:38 PM
cato's Avatar
Your dealer stinks! Mine has worked on door rattles after
2 years of owing the car. Be sure to let them know that they
SUCK.
Old Apr 28, 2004 | 01:47 PM
SixFive's Avatar
fixing a problem is not an adjustment - you should contact infiniti north america.
14.2 @ 97.18
Injen CAI
UR Crank Pulley
Old Apr 28, 2004 | 02:49 PM
doogie's Avatar
Check out my freshalloy posts on
Rattling Door Clips
Additional Rattle Protection
My advice to you is YES do these fixes yourself. With the same felt and weather stripping I've fixed ALL my door rattles and now a roof rattle that cropped up too. Now I have a B-Pillar rattle that I'm going to dig into sometime but overall my car is pretty rattle-free
the dealer sometimes introduces more rattles than they fix when they start taking stuff apart, just do it yourself and you'll guarantee the work and make sure you do a good job Plus, it's just fun.
Jase aka Doogie
04 G35S
Old Apr 28, 2004 | 08:40 PM
WinterPeg's Avatar
Thanks for the info Doogie. I am pretty good at this kind of stuff. My wife hit a piece of concrete(pole in her parking garage at work) and cracked the driver's side rear view mirror cover. I picked one up from a salvage dealer outside Sacremento and installed it myself in 1.5 hours which was less than the dealer would have charged(by time) to replace it.
If it's the clips, I know how to play with them from installing the mirror.
I'll post an update when I get around to doing it in the next couple of weeks.
Maximum Respect
WinterPeg
Old May 3, 2004 | 12:12 AM
markrief's Avatar
There are 3 screws - one behind the pull handle, and 2 under the metal trim piece. After that it's just the plastic clips. Check out the first two pictures in this:
http://home1.gte.net/res0bsc9/g35/signalmirrors.html
With a roll of foam tape, you can get rid of your rattles. I did.
Mark
2003 G35s TB/Willow/Signal Mirrors/Tint/Ground
1997 Maxima
rezendvous420
May 31, 2020 01:26 PM
xluke
Jul 30, 2016 01:48 PM
will091195
Jul 27, 2015 09:19 PM
emorehs
Jul 17, 2015 09:45 AM
