Problem with Automatic Transmission
Old May 3, 2004 | 08:19 AM
Muddy's Avatar
Hi Folks,
Recently been having a problem with my 2004 G35x, only 3500 miles. I was curious if anyone ran into a similar issue and if it was easily resovled. The manumatic does not work, it stays in D when I shift over to the right. Thats not to bad since I can still drive it, but the worse issue is that occasionally it locks into 1st gear (in normal driving mode) and won't shift up. I have to pull over and restart the car, at which point it works fine. This just started and it has only occured maybe three times. Thanks for any feedback.
Old May 3, 2004 | 10:41 AM
Andyl's Avatar
Re: Problem with Automatic Transmission
If thats the problem I would deffinitly bring it back to the dealer and have it fixed.
Old May 3, 2004 | 11:18 AM
cato's Avatar
SouthernComfort Moderator
Time for a trip to the dealer. I hope you have a good one.
2003 TwBlue 5AT Sedan, sunroof,
Graphite Leather, splashguards, HKS exhaust,
14 wire Grounding kit, 350Z duct, Stillen CAI
Underbody rear diffusers, Drilled alum pedals
Old May 3, 2004 | 12:00 PM
Gmaster's Avatar
Hmmm. First time I ever heard. Bring it back to dealer and get them fix.
04 G35s 5AT
Old May 3, 2004 | 02:04 PM
JKRD101's Avatar
Someone I know had the same problem as yours (will not shift out of 1st gear, and MM mode will not work, also his sport/comfort mode was not functional), but he has a 03 CL500. His TCM (transmission control module) was replaced, and he had leaking transmission fluid. However, when he restarted the problem didnt go away. I would either tow your G or have it looked at right away!
derres
Aug 28, 2015 03:27 PM
saskicker32
Aug 11, 2015 02:12 PM
Srinidhi
Aug 7, 2015 03:38 PM
newg37
Jul 26, 2015 09:32 AM
newbdriver01
Jul 15, 2015 06:10 PM
