Running on Fumes...
As a general rule of thumb you should never really go below 1/4 tank just to make sure you don't mess up your engine or any components of the fuel system.
In the G, the fuel light comes on at just under 1/4 tank. I wouldn't wait any longer than that to fill up unless you absolutely had to. Just not worth it
Originally Posted by UR2EZ
actually, you're wrong....... it's not about 'sediment'...
"the fuel up is located inside the gas tank to help "muffle the buzzing noise produced by the electric pump motor, and immersing the pump in fuel helps lubricate and cool the pump motor.
"Driving with the fuel tank less than one-quarter full, can shorten pump life by causing it to run hot. It also increases the risk of momentarily starving the pump for fuel when cornering sharply, braking or accelerating.
"Running out of gas can sometimes damage an electric fuel pump by starving it for cooling and lubrication."
Thebaws11
07-02-2021 11:36 AM
Thebaws11
11-30-2016 12:54 PM
n2fooz
09-04-2015 07:46 PM
