So my fuel door actuator died
Old Jan 7, 2009 | 09:53 PM
G SEDAN's Avatar
mine died at 30k, didnt have tools to do anythign so i opened up the trunk and broke the plastic lock off the mechanism.
it was replaced under warranty........when i HAD warranty
Old Jan 8, 2009 | 12:21 PM
dmitriylm's Avatar
It's just kind of sad that such a simple part experiences such a high failure rate in a luxury vehicle. It's not exactly a component that gets a huge workout either.
Old Jan 13, 2009 | 10:12 PM
snicol1's Avatar
how do you open it manually??? mine just happened tonight and i am supposed to be moving from baltimore md to tampa florida on thursday so i cant exactly put it in the hsop
Old Jan 13, 2009 | 10:26 PM
coolieman1220's Avatar
on the right side of the trunk (passenger side where fuel door is) you take out the interior sound deadening pannel. be careful not to rip it. there are 4 clips that you can take out with a clip remover or a flat screwdriver. then you kinda just take the piece. wiggle it out its in there good. it has flanges connected to the other pannels and the carpet. once its out just push it to the side and reach in and feel for the motor. there's a lil piece sticking out with a groove, just pull that back and it opens!
Old Jan 13, 2009 | 10:29 PM
snicol1's Avatar
thanks coolieman sounds like i am going to have to get my hands dirty tommorow....what are we talking about here?? 15 minutes?
Old Jan 13, 2009 | 10:34 PM
eh not really dirty. i just jumped in the trunk and got to work. the pannels are big and sturdy so its a pain to put places. it takes a lil while to put back together to line up the holes for the clips. it should take 10 minutes. its quick and easy. while you're at it tie a string to the back of it and tape it on then run the string into the trunk around the pannel and tie the other end to the top of the trunk area so that if it does stick again you can pull the string and open it. if you want to get ambitious take it out and run a 9v battery to the terminals to see if it works and shoot it with some grease to see if it works cause mine is moody. to take it out you unscrew the plastic ring in the fuel door area then push in a clip and pull the motor out. good luck and have fun!
Old Jan 13, 2009 | 11:34 PM
snicol1's Avatar
thank you have been very helpful...here i am thinking that i wouldnt be able to move thursday but it looks like i am tampa bound
Old Jan 14, 2009 | 06:08 PM
obender66's Avatar
Mine is kinda on and off. Seem to be off when it is really cold outside. I'll try cleaning it.
Old Jan 14, 2009 | 06:27 PM
erklep's Avatar
its a common problem with nissans/infinitis. we get a few a week at my place. if the cust insists on replacing, we charge 3/10ths which is about 28$ to replaced plus the cost of part. but if im dealing with a good customer, you can actually just undo the clip, pull back the panel and squeeze your arm in there to unplug the actuator. the door will still function as always but will not able to be locked. not a big issue in my eyes unless gas theft or tampering is common in your area. even then, the door can still be opened with minimal force and damage
Old Jan 14, 2009 | 09:28 PM
Braintree's Avatar
The first "mod" I made to the car (day 1) was unplug the unit. Most would consider this insane, but after >2 years with the car, never had a problem of stolen gas or those who really like me throwing sand and sugar in the tank! My car spends most days in an urban, extremely low income, high crime setting (it sleeps in a garage at night).
Old Jan 15, 2009 | 12:07 AM
agreed!
i hear murano's have the same issue....
Old Jan 15, 2009 | 07:49 AM
snotf's Avatar
me too, it was that or get stuck on the jersey side of the G dub waiting for a tow ... now i just have a tilt to open gas tank.
Old Nov 27, 2009 | 12:04 PM
Ahnuld's Avatar
75K miles. Thanksgiving. 100+ miles to go and won't open. Running on MT. Thanks for the liner tip. iPhoned G35Driver. Remove trunk liner. Et Voila! Thanks guys!
Old Nov 27, 2009 | 05:03 PM
WILLIE BEANS's Avatar
Originally Posted by mIKE
Forwarded to Rick. You'll have an answer within 24 hours
anything from rick ?? on price??
Old Nov 27, 2009 | 09:01 PM
  #30
XDR-V35's Avatar
mine seems to be intermitten. only actually seen it lock once when i locked the doors to prepay and came back out to try and open it. just went to check and see if its locked now and it isnt but the doors are.
