So my fuel door actuator died
Old Nov 28, 2009 | 10:56 AM
  #31
Ahnuld's Avatar
coolieman1220, thanks for the tip. I lubed with some WD-40 as a temp fix. So far so good. White lithium grease should do the trick - hopefully. Keeping my string around just in case.
Old Jan 30, 2010 | 06:26 PM
  #32
Cricker's Avatar
Helpppp
My fuel door just flops around. The mechanism works fine but found that the little black clip/spring was broken at the hinge. Picked up a new one from the dealer for $6 but can't figure out how it goes on!!! Can someone please post a pic of your gas door open so I can see how the little black clip sits on the hinge??? THanks
03' sedan, 6sp manual....
Old Oct 11, 2010 | 07:27 PM
  #33
bergy52's Avatar
Thanks for the quick solution. My just failed/stuck today at 69k. Unplugged the motor and will go the manual route as mine is either on the road or in the garage.
Old Dec 7, 2018 | 06:37 AM
  #34
Brook Gude's Avatar
19" alloy, nav package, Bose sound
Originally Posted by dmitriylm
It's just kind of sad that such a simple part experiences such a high failure rate in a luxury vehicle. It's not exactly a component that gets a huge workout either.
it gets a harder workout than you think... Every time your doors unlock it unlocks, and every time your doors lock it locks... So it gets the same workout as your power door locks
Freeman186
Sep 6, 2023 10:07 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
TNRocker
Sep 21, 2015 08:36 AM
JustinMKN1
Sep 18, 2015 03:40 PM
AT23
Sep 15, 2015 07:44 PM
