Outside Temperature Gauge
Old Oct 2, 2008 | 05:27 PM
pottie's Avatar
Got my 05 X recently bout a month or so and I notice lately my temperature gauge for outside temperature act slow...
I always park my car inside the garage and when I drive it out it ll take 5-10 minutes for temperature to adjust with current outside temperature
Is this normal cz shouldnt take that long right
I notice after 2 miles ride it only drop 2degree and still dropping
Have anyone ever have this problems, thanks for input
Old Oct 2, 2008 | 05:30 PM
cremaster's Avatar
mine is pretty slow, too. sometimes it'll get stuck at a certain degree when i know it's 20 degrees hotter.
Old Oct 2, 2008 | 06:42 PM
ttrank's Avatar
Grocery getter
That's normal. If they made it change at a very fast rate it would bounce all over the place, especially when you are in stop and go traffic.
Old Oct 3, 2008 | 09:54 AM
pottie's Avatar
Cool thank s for the input Tim
I just checking while I m still under warranty from factory..
I think I might go with H&R sport spring once I got my wheels
Old Oct 29, 2008 | 10:47 AM
GzUpHozDn's Avatar
Is it supposed to be that slow tho??? kuz I had an '06 G n it was A LOT quicker, more real time temp than my now '05 G...and doesn't the climate control adjust the airflow and A/C to compensate with the outside temp?? kuz I also noticed that the climate cont temp is way off...for instance it states 90 degrees outside when it's really about 76 degrees and when I turn on the Auto A/C, it blows hella hard and cold as hell when set to 77 degrees...and in the '06 G 72 degrees barely made it blow strong and cold...but was on point and perfect temp....
Old Oct 29, 2008 | 12:04 PM
pottie's Avatar
Yeaap I noticed the temperature back to normal after car running 2-4miles
Then everything back to normal
Thank s for the input guys
Old Oct 29, 2008 | 01:06 PM
Truth's Avatar
What about the compass? Mine shows 3 dashes, it has stopped working. Not that I used it but I like all things to be working. Do I have to re-set something?
Old Oct 29, 2008 | 01:57 PM
lexusk8's Avatar
^ Here is the correction procedure as stated from the owner's manual:
Correction procedure
1. Push COMP switch for about 10 seconds. The direction bar starts blinking.
2. Turn off electrical equipment such as lights, hazard indicator, air conditioner, etc. Then drive the vehicle slowly (less than 3 MPH (5 km/h)) and turn the vehicle one or more times in an open and safe area. When the
compass displays the direction, the procedure is completed.
Old Oct 29, 2008 | 04:25 PM
Truth's Avatar
Thanks i'm going to give that a shot.
Old Oct 29, 2008 | 09:48 PM
llut5at's Avatar
so doughnuts in a parking lot wont work? :P jk heh
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
alessandro
Oct 8, 2015 09:29 AM
9tray turbo
Sep 29, 2015 10:22 PM
JustinMKN1
Sep 18, 2015 03:40 PM
mattdg35
Sep 14, 2015 11:28 AM
