Brake Dust Shields
Old Oct 12, 2008 | 11:28 AM
Wiseman's Avatar
Brake Dust Shields
Hey guys. Have any of you installed brake dust shields on your wheels before? I'm considering getting a set of them due to excessive brake dust but at the same time don't want to ruin the style of the car. Does anyone have any pictures with them installed?
Old Oct 12, 2008 | 11:30 AM
Foques's Avatar
ugh.. eww....
Old Oct 12, 2008 | 12:19 PM
Noremac's Avatar
If dust is a major objection to you, I would strongly recommend changing the pads to ones that don't dust as bad. This usually involves a tradeoff in performance, but it's not nearly as bad as the tradeoff you get by using dust shields - which can cause extreme overheating problems. Don't do it
Old Oct 12, 2008 | 12:27 PM
NismoGirl2001's Avatar
I used a really good cleaner on my wheels then waxed them and it helped. It doesn't help with the dusting problem but it does make cleaning them much easier b.c it doesn't tend to bake on. I clean my wheels a couple times a week though
Old Oct 12, 2008 | 12:30 PM
cerr's Avatar
switch over to a different set of pads - hawk has some good options that won't dust the crp out of ur wheels
Old Oct 12, 2008 | 12:45 PM
coolieman1220's Avatar
i just clean em, if you kept em clean from day one they stay easy to clean!
Old Oct 12, 2008 | 01:34 PM
G35Papa's Avatar
If you have OEM wheels, another suggestion is to apply a wax to them. It will help keep them clean and also alot easier to clean them.
A big no from me on the dust shield.
Old Oct 13, 2008 | 02:22 PM
ttrank's Avatar
Grocery getter
My ex-mother in-law put those on her G sedan. It made the wheels look like hub caps. I vote NO!
Old Oct 13, 2008 | 03:57 PM
Trbulnt's Avatar
Plus 1 on different pads. I just switched to some Ceramic pads from the local Advanced Auto and no longer have a serious dust issue. Even after a spirited drive this weekend.
Old Oct 13, 2008 | 05:18 PM
5150DS's Avatar
I say go for it, but paint them red or have them chrome dipped first. Then get spinning hub caps from your local parts store to finish the look.
Old Oct 13, 2008 | 06:10 PM
Boston's Avatar
Wheel wax for easier cleaner or Hawk pads but no way on the dust shields.
Old Oct 13, 2008 | 10:20 PM
thehitt's Avatar
nope
don't do it lol! wax the wheels nice and the dust won't bake on as others have said.
Old Oct 13, 2008 | 10:29 PM
Nickk6's Avatar
I don't know if they have it for the G35, but I used EBC green stuff brake pads on my Nissan Altima with drilled/slotted rotors. I had less dust up front than I did with the oem pads in the rear. Performance was comparable, if not better than stock.
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
Gabe83714
Oct 6, 2015 06:40 AM
alinero718
Sep 27, 2015 09:35 PM
