Car Is Jerking!!!!!!
Old 10-12-2008, 07:57 PM
AARONHL's Avatar
My 2004 GSedan 6MT jerk/bucks when I get off the gas pedal after speeding up a little. My clutch isn't slipping and the SES is off. I also feel a slight vibration in the gas pedal but don't know if it's related.
If I'm going about 40mph and then let go the gas, there would be a faint/slight jerk throughout the car and if I hit the gas right after, it would jerk a little bit more. For example, it happens around 3,000rpm, similar to say if you car was at 5,000rpm and you gas it and let go. That kind of "jerk" but not as violent. [THANKS joedaddy1]
Any chance you know what it is?
Old 10-13-2008, 10:06 PM
AARONHL's Avatar
BUMP!! VERY ANNOYING IN RUSH HOUR TRAFFIC!!!!! And no, this isn't the regular "jerk" you get with a standard car.
Old 10-13-2008, 10:14 PM
Fabrikator's Avatar
in any gear?
Old 10-13-2008, 10:27 PM
AARONHL's Avatar
I notice it in 3/4/5 the most because I am usually up to a little speed. Although I'm pretty sure it happens in every gear.
Old 10-13-2008, 10:30 PM
Sacch's Avatar
Just have more sex with or in your car and it will stop jerking!!!
Old 10-13-2008, 11:52 PM
AARONHL's Avatar
Not surprised, knew it would catch people's attention!
Old 10-14-2008, 12:05 AM
mIKE's Avatar
that's normal in ANY manual transmission car... accel vs decel load.
Old 10-14-2008, 12:12 AM
AARONHL's Avatar
No, it's more abrupt than that, I know what a manual shift car does. This is a quick, slight jerk back and fourth a couple times.
Old 10-14-2008, 02:00 AM
AARONHL's Avatar
While stopped at street lights (in neutral, no brake) I can feel a rough idle and a shaking car. I don't know if that is connected or if all G35s do that.
Old 10-14-2008, 10:06 AM
psedog's Avatar
Back in SD**
There is a TSB for this. It is a throttle body issue.
To Mike, I have the same issue and I have an 06 AUTO. Unfortunately I can't get warranty work out here in JDM land
This is the TSB # for the 05-06 models.
ITB07-030
http://x.infinitihelp.com/forum/loca...d&pp=10&page=2
EDIT:
Apparently the TSB only addresses AUTO's. The TSB says to Replace the transmission valve body (control valve assembly).
Old 10-14-2008, 01:28 PM
joedaddy1's Avatar
hey, do you have a rattling noise in low rpms?
I think I have a timing chain tensioner issue and MAYBE that is causing this "slack" in accelerating and decelerating.
Old 10-14-2008, 02:13 PM
AARONHL's Avatar
Explain the rattle noise in low RPMs...
Old 10-14-2008, 03:25 PM
joedaddy1's Avatar
usually 2nd/3rd/4th gear..
when you are in 1.5k~2k rpm.. when you have the gas pressed.. there's a faint chain dragging/rattling noise from the engine/firewall area.
Trying to figure out if it's the heat shield from the CAT, the timing belt tensioner, or something else.
Also, how many miles are on your car and did you ever change the drive belts?
Old 10-14-2008, 09:02 PM
AARONHL's Avatar
I was thinking about tightening my belts. My G has 88k miles on it and I bought it earlier this year in great shape. I'll try to notice that noise...
Old 10-16-2008, 12:32 AM
AARONHL's Avatar
I think my CP -> AC belt is way too loose and pretty old. Might try changing that.
Quick Reply: Car Is Jerking!!!!!!
