Noob Question - how to remove stock jack
Old Oct 17, 2008 | 09:45 PM
Smokey6's Avatar
sorry for the dumb questions guys, just wanted to ask how to get the stock jack out of the car. I'm sure I could figure it out with time, but if someone can tell me how to get it out of that little cubby in the trunk without effort, it'll probably come in handy one of these days.
Thanks in advance.
Old Oct 17, 2008 | 09:53 PM
JOKER's Avatar
CLUB MODERATOR
turn it counter clock wise. Once it's compressed enough you can pull it out of it's plastic holding thing.
Old Oct 17, 2008 | 11:24 PM
gtbigup01's Avatar
^ what he said. Once you get used to it, it's actually easy to put in and take out.
Old Oct 18, 2008 | 03:32 AM
ttrank's Avatar
Grocery getter
I'm shocked you had to start a thread to ask how to get the jack out.
Old Oct 18, 2008 | 01:17 PM
Smokey6's Avatar
Yeah yeah I know. Pathetic.
I didn't even try, just looked like a bit of a tight space so I figured I should try getting it out once before I need it in an emergency. I thought asking first would be helpful.
I'm actually reasonably mechanically inclined. I did the spacer on my own as well as opening up my headlights on my g35. On my old mx6 I did struts/shocks replacement, inner tie rod replacement, caliper replacement with brake bleeding, master clutch cylinder replacement and system bleed, etc. etc. etc.
Just seemed easier to ask first rather than trying. Perhaps it would have been better to simply pm someone, but oh well. I'm sure someone down the line might find this thread useful...
Old Oct 18, 2008 | 04:03 PM
OCG35's Avatar
the first couple of times are a bit tricky... I needed help the first time I took mine out... it’s an awkward fit until you are used to it.
Old Oct 18, 2008 | 05:28 PM
lexusk8's Avatar
The location of the stock jack in our cars is the dumbest location I've seen. I'm glad my jack finally broke (after using it countless times for tire/brake jobs) so that I never need to reach into that cubby spot in the trunk
Old Oct 20, 2008 | 05:45 PM
joedaddy1's Avatar
how do you put it BACK IN?!?!
man.. i can't believe i am having the hardest time..
can anyone take a pix of the position it needs to be in?!?!
Old Oct 20, 2008 | 06:04 PM
OCG35's Avatar
it goes in upright... it would be hard to get pics since its hard to see into the cubby... kinda have to "feel" it... put the jack at its lowest position, place it in the compartment upright with the turning mechanism facing out - it will rest on its bracket, then turn it open/extended a bit until its snug and doesn’t move.
Not the best explanation, but that’s all I have
After you've done it a couple times, its second nature.
Old Oct 22, 2008 | 08:52 PM
Smokey6's Avatar
see...I knew I wasn't the only one who found this a little complicated.
Old Oct 23, 2008 | 02:45 AM
heyitzalex's Avatar
putting the stock jack back in definitely takes some getting used to
Old Oct 23, 2008 | 10:44 AM
skull_leader's Avatar
jack
its harder to put back than takeing it out... mine is sitting in the cargo net...
Old Oct 23, 2008 | 11:11 AM
Boston's Avatar
The OEM jack for the G35 is a POS. I suggest chocking your wheels to ensure the car doesn't move at all as my jack collapsed and I know other members have had the same issue. I got a replacement Nissan jack from an 08 Altima and the difference is night an day. At least I can use it in an emergency.
Old Oct 23, 2008 | 11:37 AM
Smokey6's Avatar
haha - #13 posts. Guess this wasn't as stupid a post as you thought Ttrank
I just figured it out. Now it is very simple. Yes, you all said the same thing, but I'll try explaining it my way.
To remove: Twist the tab with the hole on it counterclockwise to lower/collapse the jack. The jack should slide out of the hole.
To replace: Ensure the jack is collapsed fully. Insert the jack into the cubby hole such that the tab with the hole in it is still visible (ie. insert the opposite end). Now holding the jack in the fully inserted position, twist the tab with the hole clockwise until the jack has expanded/risen such that it fits the contour of the hole that it is seated it. Really it is just the jacks expansion that puts tension on the surrounding case that keeps it in place.
I hope this helps those that had difficulty removing/reinserting the jack like me.
Old Oct 23, 2008 | 02:54 PM
RicoG35x's Avatar
guess it's safe to say that this design is kinda... "JACKED UP"?!?!?!
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
DRG35R
Jul 31, 2015 10:23 AM
