1st Gen Sedan - 4.2L, T-Trim, Widebody, Full ICE, etc
Has anyone seen this car before??
Engine & Driveline
Brian Crower 4.2 Litre Stroker
Darton Sleeves
JE Pistons (Coated)
L19 Head Studs
Brian Crower Forced Induction Cams
Billet Stroker – Crankshaft Girdle
Vortech Polished V1 T-Trim Supercharger 22psi Turbine
Vortech 2.87" Blower Pulley
Greddy E-Manage Ultimate Piggyback ECU
Altered Atmosphere Factory EMU Re-Program Red Line Raised to 8000 RPM, Speed Limiter Removed & Programmed for 650cc Injectors
RC 650cc Fuel Injectors
Altered Atmosphere Billet Aluminum Fuel Rails
Altered Atmosphere Stage 2 Fuel System c/w Bosh Pump & Surge Tank
Walbro 255 L/H Fuel Pump
FJO Racing Water Methanol Injection c/w ECU Data Logger
FJO Racing Digital Wideband O2 c/w ECU Data Logger
Alphawerks Stainless Steel Equal Length Headers
Stillen Stainless Steel Cat Back Exhaust System
Kinetix Racing Stainless Steel High Flow Catalytic Convertors
Kinetix Racing SSV Polished Stainless Steel Intake Manifold
Vibrant Performance Front Mount Intercooler
DEI/Cry O2 Intercooler Sprayer System c/w Dual Spray Bars
Vibrant Performance Silicone Reinforced Hose Connectors
Vibrant Performance Aluminum Intercooler Piping
Custom 3" Polished Intercooler Piping & MAF Sensor
Koyo High Capacity Aluminum Rad
Custom Dual Flex-O-Lite Electric Fans c/w Temp Control Speed Drive
7 Wire Hyper-Tech Engine Grounding Kit
B & M Transcooler c/w Thermostatic Controlled Fan x 2
Suspension
Tein Flex Coil Overs c/w Adjustable Compression
Cusco Front Upper Control Arms
SPC Rear Lower Control Arms and Tow in Adjusters
Stillen Sway Bars
Rolling
Stoptech 14.2" – 4 Piston Big Brake Kit on all Four Corners c/w Braided Stainless Steel Lines
One Off HRE 591R 19" 3-Piece Wheels 19 x 9.5 Front/19 x11.5 Rear
Toyo T1R Tires 265/25/ZR19 Front 315/20/ZR19 Rear
Body
All Metal One Off Wide-Body 2" Stretch in Front – 2-1/2" in Rear
Advanced Import Tuning 4 Piece Body Kit c/w One Off Customization Of Front Clip To Fit Intercooler and Wide-Body
Customized Body Kit to Fit Wide-Body
Factory Front Bumper Re-Made, Boxed, Gusseted & Reinforced To Accommodate Oversized Intercooler (Still Maintains All Factory Airbag Sensors Ect)
JDM Brake Booster Cover
Custom Made Fiberglass Engine Cover
Lighting
Hella Driving Lights
Varad LED Undercar Kit
5 Varad LED Suspension Lighting Systems Throughout & Inside Car
3 Varad LED Headlight Flashers
ICE
Kenwood Excelon DNX8120 Head Unit c/w 5.1 Dolby Digital and DTS
Front Stage LTR Focal Utopia #7
2nd 6 1/2" Mid-Base Bi-Amped
Centre Channel Focal Utopia #5
Rear Surround Focal Utopia #5
2 – Focal KX33 Subwoofers
Steg Amplifiers K02-03 Powers #7
K02-02 Powers Bi-Amped Mid-Base
K02-02 Powers Centre #5 and Rear #5
K04-01 Powers Trunk Lid Audio
K02-04 Powers Subwoofers
1-Pair Focal K2 165 Power Speakers on Each Side of LCD Screen On Rear Deck
1- Focal 100 K2 Power Components as Centre Channel On Rear Deck
2 – Focal KX 33 Subwoofers Inverted In Trunk
2 – Audison 1.3 Farad Cap c/w Digital Displays
17" LCD Screen in Trunk
2 - Vizuglogic Factory Matched 7" Headrest Monitor System
2 – 8" LCD Visor Screens
1 – Playstation 2 c/w Wireless Controllers
3 – Kinetics HC1400 Batteries
Audison Connection Wire to All Amps. (Power and RCA)
Audio Control DQS – 6 Channel Digital Equalizer
Audio Control DDC Equalizer Control, Custom Molded into Dash
Stinger Amperage Voltage Distribution Block
200 sq. ft. Brown Bread Sound Deadening
Misc
Samco Silicone Coolant Hoses
Vibrant Supercharger Hoses
Custom Dual A- Pillar Pod c/w FJO Racing EGT & Wideband O2 c/w Data
Logging
Custom Centre Console Side Pod c/w Fuel Pressure, Oil Pressure & Boost Pressure
Pi-Thon Rad Hose Ends & Caps
JDM Endura-Tech Hood Dampers
Engine & Driveline
Darton Sleeves
JE Pistons (Coated)
L19 Head Studs
Suspension
Stillen Sway Bars
Rolling
Body
Lighting
ICE
Misc
Logging
Forget how ugly it is. Look at how wide the rear wheels are
Any dyno sheets? Who owns it? Why is he not on here??? Any other pics?
With those injectors it cant be more than about 600 RWHP. Should of been turbocharged instead.
http://www.vortechsuperchargers.com/...?cat=4&gik=342
It's automatic. **** it.
Looks like it's an 03-04 with the Premium package. Can anyone tell me? I see AC vents in the rear. The center console looks like an 05-06 one.
The owner names are Brent and Rhonda Mills.
Yeah that's where I found it.
I just got the AAM stage 2 fuel system with the surge tank and bosch race pump. I was looking for pics of it installed and found this car.
Originally Posted by B L U E S L A T E
Holy shiet that thing is ugly...., but I wonder what kinda power would it put down...
Well, now that I think about it. Maybe not, I have not seen very many autos in that range. I'm not sure...
Fuel system upgrade for your car??
How much RWHP will you be able to get out of the car with it installed?
I would like to see at least 600-625whp. I may be able to get the Greddy turbos into the 700's but that's a long shot. They'll be maxed by that point.
Originally Posted by ttrank
My wife got it for me for my birthday. I didn't know. She said I only turn 30 once and she wants to make sure I get something I really want. She's so cool, I don't know how I got so lucky.
