Sedan Specific Rear D-Spec Adjusters
Old Oct 23, 2008 | 07:39 PM
OCG35's Avatar
Does anyone have DIY or install diagram for the adjuster extension cable for rear Tokico D-Specs?... I found this one for coupe:
https://g35driver.com/forums/brakes-...35-coupes.html
But the base sedan is different - seats don’t fold down... I have non-premium so no recline in rear.
Anyone know the best method of installing the adjuster cable?
Old Oct 23, 2008 | 09:44 PM
5150DS's Avatar
I believe you have to drill holes in your wheel wells.
Old Oct 23, 2008 | 11:31 PM
OCG35's Avatar
bump - a lil help please... anyone?...
Old Oct 23, 2008 | 11:37 PM
CandlestickPark's Avatar
ill Sedan
Mike, PM Dexter (dahkyne), he has them installed and routed behind his back seat headrests. I'm going to be doing this pretty soon too.
Old Oct 23, 2008 | 11:39 PM
OCG35's Avatar
cool - thanks Marcus
Old Oct 24, 2008 | 12:29 AM
dahkyne's Avatar
yo... you gots PM
Marcus... I can still get the adjusters for you... let me know when
Old Oct 24, 2008 | 12:33 AM
ill Sedan
Originally Posted by dahkyne
yo... you gots PM
Dexter, I still want them, for sure. I'll pay you at the next meet or we can meet before then.
Old Oct 24, 2008 | 12:34 AM
dahkyne's Avatar
theyre not that special that it would require doing something that drastic....
the cables arent necessarily specific to a sedan or coupe, but there are 2 lengths for FM chassis applications... the shorter of which is what is normally used
if anyone plans on buying them, theyll look long at first... but they reach perfectly
the extra long ones are just that... extra long... and not needed
Old Oct 24, 2008 | 12:37 AM
dahkyne's Avatar
maybe we can get a small install day for these... im sure mike would be down for it
gonna call my dealer for them tomorrow...
Old Oct 24, 2008 | 12:40 AM
ill Sedan
I'm definitely down for that. I need to remove those stickers from the underside of my hood too.
Old Oct 24, 2008 | 12:22 PM
OCG35's Avatar
Marcus, if you set something up, let me know soon - I already ordered mine from Stillen ($25) - they are due next week and I planed to take to Temple City to have installed with d-specs and SPL A-arms... if something else is shakin' I'll hold off...
BTW, what’s up with the fluid reservoir caps?
Old Oct 24, 2008 | 12:30 PM
OCG35's Avatar
yo... you gots PM
Thanks Dexter
Old Oct 24, 2008 | 12:42 PM
ttrank's Avatar
Grocery getter
If I remember right you have to drill a small hole and poke them out by the rear deck.
Old Oct 24, 2008 | 01:37 PM
dahkyne's Avatar
im not sure if that would apply to 05-06 sedans, as mine didn't need drilling at all... maybe the area under the rear seat was reshaped between years that required it on older cars... possible
basically, i took the rear seat out, screwed them onto the tops of the shocks, replaced the seat, and reset the shock adjustment... took an hour at most, working slowly
Old Oct 24, 2008 | 01:44 PM
dahkyne's Avatar
I would suggest getting the shop to do it if they're already going to be in that area of the car anyway... BUT...
if they cant, we can work out some install schedule and get them in there for you... hopefully the drilling part isn't applicable to your car.
