is this normal????
Old Nov 16, 2008 | 03:49 PM
STCLAIRWEST's Avatar
is this normal????
i have a 04 5AT sedan and when i use tiptronic everytime i shift to the next gear it has a second or 2 second delay before it gets into gear. is this normal?? should it shift into gear right away??
Old Nov 16, 2008 | 03:53 PM
1SlowSedan's Avatar
OMG Don't shift in tiptronic your car is going to blow up!!!!!!!
jk, yes it is normal
Old Nov 16, 2008 | 03:55 PM
i swear it feels wierd, in my other friends cars with tiptronic it shifts right away with no delay
Old Nov 16, 2008 | 03:56 PM
Blue Meanie's Avatar
Yup.. The delay is awful, however, the more you use it, the more you can shift where you want by shifting a fortnight earlier... Despite the delay, I use it, and it's pretty decent on the whole. It seems to be, flat out, about 500rpm delay, so shifting at 6.5, change at 6, and you'll be on the nose, ish.
Apparently the grounding kits speed it up, but if they are a placebo I don't know. seem to be mixed reports.
Old Nov 16, 2008 | 03:58 PM
has anybody used it ALL the time? is it known to be more hard on the transmission and will have problems coming if used often?
Old Nov 16, 2008 | 04:18 PM
naylikewhoa's Avatar
i rarely use it cuz of that delay when u swtich to it, but idk ima try it more often .. so if it gets smoother thru time
Old Nov 16, 2008 | 04:41 PM
FutureGDriver's Avatar
i use it on the highway to get more MPG.....mines does not do the delay cuzz i floor it all thru the gears..
Old Nov 16, 2008 | 04:43 PM
g35freak86's Avatar
I literally use it EVERYTIME I drive, which is everyday. I never drive in D anymore. Been using Tiptronic for a good year straight now. Over time, the computer learns how you drive ad the delay isn't as bad. I've done it so much that I've timed it out and know exactly when the car shifts so I time up the gas and when it gets into gear perfectly.
Old Nov 16, 2008 | 05:54 PM
Tollboothwilley's Avatar
Do yourself a favor...get a GOOD set of grounding wires. Makes this car feel 100% better. Shifting in triptronic happens much faster and you don't feel a lag. Best bang for buck mod I've put on my car...must do for a 5AT.
GroundingGear kits are good...there is also a guy in socal making grounding kits. He's on a diff website. pm for more info...not sure but his might be cheaper and you'd get them faster then waiting for canada to get them here.
Old Nov 17, 2008 | 04:15 PM
what do u mean waiting for canada to get them here? do u mean it will take long to get to canada?
Old Nov 17, 2008 | 04:22 PM
G35Papa's Avatar
He's referring to Gordee's "GroundingGear" grounding wires.....Gordee is from Cananda.
Old Nov 17, 2008 | 04:36 PM
so it will be faster for me since i live in canada
Old Nov 17, 2008 | 04:47 PM
mikeee2's Avatar
Haven't posted for a longgggggggg time.
I have Gordgee grounding wires myself but I really don't feel a difference at all. The G is my first automatic car and only had m/t before. When I first bought the G I try to use manual model and see if I can get used to it / adjust to it but the LAGS are just everywhere. Basically, I don't use manual mode at all except when I need to merge into the highway, then I put it in a gear so this way I can just downshift and go.
Other than that the transmission is fine but manual mode is a no-no. I swear to myself, my next car has to be M/T again (unless it's a van/suv).
Old Nov 17, 2008 | 04:48 PM
canucklehead's Avatar
^ gordgee is in edmonton. so you'd just have to get shipping to TO.
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
aaron3719
Sep 29, 2015 10:12 AM
vamarris
Sep 26, 2015 12:56 PM
