g35 problem!!!
Old Nov 24, 2008 | 09:35 AM
towerace1's Avatar
g35 problem!!!
Hey guy's I am new here and also a new g35 owner. I just bought a 04 g35 sedan fully loaded with 43k for $11.000.00. A good deal I thought but yesterday I got on the gas and when I stopped at the light my car started to run really bad at idol and just shut down on me. I took it and had the code pulled and all it said was low rmp? Any info will help..
Thanks
Old Nov 24, 2008 | 01:41 PM
lexusk8's Avatar
Please specify what the code number is (usually stated as "P####" where '#' is a number 0-9). And I'm not sure what you mean by "low rmp"? BTW, 11 grand for a fully loaded 04 with average miles is a really good deal.
Old Nov 24, 2008 | 02:29 PM
towerace1's Avatar
It did not show a code # it just low rpm? But I did just pick it up form the dealer and they said the problem was the MAF was full of gunk and that my air filter is dirty, does that sound right to any one? And yes 11k was a great deal that is why I bought it..
Thanks
Old Nov 24, 2008 | 04:32 PM
ttrank's Avatar
Grocery getter
That sounds right to me.
Old Nov 24, 2008 | 06:37 PM
kmckis1029's Avatar
i would replace the the intake air filter and the cabin air filter and clean the mass air sensor... who ever had that car beofre you must of never replaced it... for it to get that bad and suffacate your engine wow
Old Nov 25, 2008 | 10:21 AM
towerace1's Avatar
thanks, i am going to install a intake any one know of a good brand for this car?
Old Nov 25, 2008 | 11:48 AM
Klubbheads's Avatar
No, stay with the stock system.
Old Nov 25, 2008 | 11:52 AM
towerace1's Avatar
Why stay with stock?
Old Nov 25, 2008 | 11:53 AM
Klubbheads's Avatar
Do a search in about intakes and u will see.
Stock BOX is one of the most efficient intakes compared to the aftermarket intakes out there.
Old Nov 25, 2008 | 11:54 AM
towerace1's Avatar
ok should I just add like a k&n filter then?
Old Nov 25, 2008 | 11:55 AM
Klubbheads's Avatar
That is a personall choice. If u do, make sure u clean it at least 10k miles.
Old Nov 25, 2008 | 07:24 PM
Qbrozen's Avatar
Did you buy the car from an Infiniti dealer?
Did you pull a carfax? (not that it is definitive, but it can't hurt)
Honestly, its a bit "too" good of a deal. And its true what they say, "if its too good to be true..."
Old Nov 25, 2008 | 07:26 PM
AARONHL's Avatar
Clean your throttle body, replace your air filter, and clean the MAF (like the dealer said).
Old Nov 25, 2008 | 07:59 PM
towerace1's Avatar
I did pull a carfax and it was a single owner car with no damage reported. I also know the owner of the car lot that I bought it from so that is why I got such a good deal. I ended up buying a pop charger for my car. My neighbor has one and said he can't be any happier with it.
chinee
Jun 10, 2024 07:48 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
ClwMike
Jul 23, 2015 12:55 PM
attarday
Jul 15, 2015 04:03 PM
