Top $40 and UNDER mods
^you guys are dumb and that looks like $hit.....
if you take off the front panel, you can put a tape adapter in the player and run the cord behind it so the tape door is closed and of course no wire coming out.
then i ran the wire up into the upper console box so i use the mp3 player or whatever in there so it's hidden
this works great for me ..
and i dont have to take anything apart . lol
i did buy a cheap one and compared to the monster cable one it was wayyy better sound .. just my opinion .. =)
they all do the same thing but some do work better than others ..
ive had different ones .. monster works the best ..
the toshiba one i had sucked so bad it had sooo much static ...
but ..hey... its only my opinion ..
I believe they all have issues. I had a Monster in the Max and had to ditch it right after buying it. It made so much noise from the sprockets spinning I couldn't take it.
wire tuck
7$ in electrical tape.
5$ in wires ( optional )
10$ in sleeving and zip ties
wire tuck link
wire tuck link
1. RHD Battery Cover
2. JDM clear corners
3. Windshield visor tint
4. Interior led lights
5. NISMO license plate frame (not really a mod, but yea)
6. LEDs for the license plate
7. debadged trunk
8. tinted rear spoiler light
9. painted oem grill
10. G35driver decals (not a mod either...but yea x2)
11. polished bolts around plenum (about $25-30)
12. K&N drop in filter ($45)
13. Painted oem headlights
14. Painted oem engine cover
15. Windshield wipers
16. Nismo radiator cap
17. Nismo oil filler cap (knock off ones)
18. Nismo gas cap cover
19 Painted rotors/calipers? (about $35)
20. generic oil catch
21. ebay 6000k HIDs
22. Red LED in reverse light housing (while not in reverse)
23. Z-tube ($50 - I know pushing the limits )
24. DIY Oil Catch Can
25. 2 degrees andvanced ingition timing (usually free)
7. debadged trunk
21. ebay 6000k HIDs
27. Blue Batmans Overlays - Each piece or set is usually under 40 bucks.
28. Adding aux input to Bose radio. ($5.98)+tax
29. VDC disable/Yaw sensor switch[/QUOTE]
26. Drop using Z springs + DIY labor
29. VDC disable/Yaw sensor switch[/quote]
30. Home Depot Lip Less than $25
31. Refinish your stock wheels, maybe $40 -$50
32. DIY 6MT Clutch Mod ($5)
33. ebay Engine dampener ($39.99 shipped)
(Stillen Replica, pretty much EXACTLY the same as Stillens', minus the name.)
