Quote:
To the OP.
The bottom light is the Fog/high beam. Your top light is your low beam. If you have daytime running lights then you have the Canadian spec version of our car. As far as I know the US chapter never gave us the option.
Check to see if your fog switch is turned on or not. If it is off and you don't have DRL's, then check your wiring (previous owner could have had it rewired).
If the wiring is good and they still won't come on, then check the following
-If you have HID, then it sounds like your HID fuses are out, or your ballasts/ignitors have gone bad.
-If they are Halogen and have been tested on another car, then it should be your fuses (or even a rarer issue of the switch being bad)
my head lights have day time running lights which turn on when. all fuses work (fuse box on driver side, two fuse boxes in the engine bay checked). low beam does not work. As I mentioned when i turn on the lights, the high beam goes on. when i flip the high beam button in the car the high beam get more intense. When head light is removed and tested on another veheicle both lights turn on like normal. I guess the previous owner may have made the some modifications so that high beam light source fucntion as the low beam and high beam.Originally Posted by psedog
You two are going back and forth for nothing. 03's had both options. The cheapest model ~28k had cloth seats and halogen lights. To the OP.
Quote:
try to look at where ur light switch is at,Originally Posted by lightspeed1
notice u can turn ur head lights on, and theres a lil thing u can switch, i dunno what it's called, but u can switch that forward and the top and bottom will remain on. and u can switch it backward and the bottom fogs stays off.
or u can look in the manual that came with ur toy.
right..ok. that same switch, only turns on the high beam.. I've had quite a few cars now. That switch only seems to turn on the high beam. I guess there must be some modification done that i did not know about.
Quote:
oh wow, that's F*CKED up...Originally Posted by lightspeed1
wiring all messed up...
u better get it checked before a cop suggest u to..
lol
god damn ricer and their high beams!
lol
and when he gives u a ticket ask him "officer are u a ricer?"
and he will answer "why?"
be a smart *** when saying this.. "u have strobe lights also..."
lol...pleanty of cops and agents in the family.. I am sure they will like this one..lol
Quote:
i bet they will!Originally Posted by lightspeed1
i said it to my uncles alot!
lol!
they'll pull me over and walk to my car and all u hear is "UNCLE! let me off.. and dont forget to come to dinner this time!"
lol
and when he's walking to his batmobile scream out RICER and floor it. lol
So many details...... I have an 03.5 and it did come with HIDs, just had pass side low beam go out on me and called dealer to see which bulb I needed and he verified by VIN that I need HID bulbs.
